Источники питания Keen Side
Datasheet Intersil EL5172 — Даташит
ПроизводительIntersil
СерияEL5172
Приемники дифференциальной линии 250 МГц
EL5172, EL5372 Datasheet
PDF, 763 Кб, Версия: 2017-10-03
22 предложений от 22 поставщиков
EL5172IY
Elantec
21 ₽
EL5172ISZ
Renesas
33 ₽
EL5172IY
Intersil
289 ₽
ЗУМ-СМД
EL5172ISZ-T7
Intersil
EL5172ISEL5172IS-T13EL5172IS-T7EL5172ISZEL5172ISZ-T13EL5172ISZ-T7EL5172ISZ-T7AEL5172IYEL5172IY-T13EL5172IY-T7EL5172IYZEL5172IYZ-T13EL5172IYZ-T7
N12345678910111213
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsEL5172ISEL5172IS-T13EL5172IS-T7EL5172ISZEL5172ISZ-T13EL5172ISZ-T7EL5172ISZ-T7AEL5172IYEL5172IY-T13EL5172IY-T7EL5172IYZEL5172IYZ-T13EL5172IYZ-T7
2nd Harmonic-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB-59 dB
3rd Harmonic-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB-60 dB
Полоса частот250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz250 MHz
Количество каналов1111111111111
Коэффициент подавления синфазного сигнала95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB
Description250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers250MHz Differential Line Receivers
Diff Gain (%)0.040.040.040.040.040.040.040.040.040.040.040.040.04
Diff Phase (В°)0.40.40.40.40.40.40.40.40.40.40.40.40.4
Distortion Conditions2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz2Vpp, 5MHz
EnableYesYesYesYesYesYesYesYesYesYesYesYesYes
Gain AV (min)1111111111111
IBIAS6 µA6 µA6 µA6 μA6 μA6 μA6 μA6 µA6 µA6 µA6 μA6 μA6 μA
IBIAS (max)14 µA14 µA14 µA14 μA14 μA14 μA14 μA14 µA14 µA14 µA14 μA14 μA14 μA
IOUT95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA95 mA
IS (per amp)6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA6 mA
Noise VN26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz26 nV/√Hz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Headroom1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V1.37 V
PSRR58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB58 dB
Peak Temp240°C240°C240°C260°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Rail-to-Rail Input-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs
Rail-to-Rail OutputNoNoNoNoNoNoNoNoNoNoNoNoNo
Скорость нарастания800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs800 V/μs
Thermal ShutdownNoNoNoNoNoNoNoNoNoNoNoNoNo
TopologyVFAVFAVFAVFAVFAVFAVFAVFAVFAVFAVFAVFAVFA
VOS (max)25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV25 mV
VOUT7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V7.5 V
VS (max)10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V
VS (min)5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > Amplifiers
На английском языке: Datasheet Intersil EL5172
