Datasheet Linear Technology LTM2881CY-5#PBF — Даташит
Серия | LTM2881-5 |
Модель | LTM2881CY-5#PBF |
Полностью изолированный микромодуль RS485/RS422 + питание
Datasheet LTM2881
PDF, 594 Кб, Язык: анг., Файл закачен: 12 ноя 2017, Страниц: 24
Complete Isolated RS485/RS422 μModule Transceiver + Power
![]() 26 предложений от 15 поставщиков LINEAR TECHNOLOGY LTM2881CY-5#PBF Transceiver, RS422 / RS485, 1 Driver, 4.5V to 5.5V, BGA-32 | |||
LTM2881CY-5#PBF Analog Devices | 400 ₽ | ||
LTM2881CY-5#PBF Analog Devices | 1 018 ₽ | ||
LTM2881CY-5#PBF Analog Devices | от 1 209 ₽ | ||
LTM2881CY-5-PBF | по запросу |
Корпус | 15mm x 11.25mm x 3.42mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1851 |
Demo Boards | DC1503A-A,DC1503A-B,DC1746A-A,DC1746A-B |
Drivers | 1 |
Экспортный контроль | нет |
Основные особенности | Adjustable Slew Rate, Isolated |
Isolation Rating | 2500 Vrms |
Max Data Rate | 20 Mbps |
Рабочий диапазон температур | от 0 до 70 °C |
Protocols Supported | RS485, RS422, PROFIBUS |
Receivers | 1 |
Диапазон напряжения питания | 4.5V to 5.5V |
Termination | Included |
- Using the LTM2881 as an Isolated 5V Power Supply &mdash AN125PDF, 95 Кб, Файл опубликован: 5 фев 2010
The LTM2881 is an isolated RS485 transceiver that guards against large ground-to-ground differentials. An onboard DC/DC converter provides isolated 5V power to the output. This application note shows the LTM2881 configured as a dedicated isolated power supply with the RS485 transceiver disabled, providing a simple powerful general purpose isolated power supply capable of delivering 1W at 5V.Выписка из документа
Статьи
- Isolated Data Transmission and Power Conversion Integrated Into a Surface Mount Package &mdash LT JournalPDF, 1.4 Мб, Файл опубликован: 18 янв 2011Выписка из документа
Серия: LTM2881-5 (10)
- Interface > Isolated Transceivers > µModule Isolated Transceivers
- Interface > RS485/RS422 Transceivers | Extended Temperature (H & MP) Interface
LTM2881CY-5PBF, LTM2881CY-5 PBF, LTM2881CY5#PBF, LTM2881CY 5#PBF
