Datasheet Microchip DSPIC33FJ64MC202-I/MM — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ64MC202 |
Модель | DSPIC33FJ64MC202-I/MM |
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
![]() 28 предложений от 18 поставщиков Микросхема Микроконтроллер, PICmicro - dsPIC 16Bit Digital Signal Controllers 16B MCU/DSP 28 LD 40MIPS 64KB FLASH | |||
DSPIC33FJ64MC202-I/MM Microchip | 29 ₽ | ||
DSPIC33FJ64MC202-I/MM Microchip | от 369 ₽ | ||
DSPIC33FJ64MC202-I/MM Microchip | 496 ₽ | ||
DSPIC33FJ64MC202-I/MM Microchip | по запросу |
Корпус | QFN-S |
Количество выводов | 28 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 12 including complementary outputs |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 40 |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 64 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 6 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128MC202 dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC204 dsPIC33FJ64MC802 dsPIC33FJ64MC804
Серия: dsPIC33FJ64MC202 (10)
DSPIC33FJ64MC202I/MM, DSPIC33FJ64MC202 I/MM
