Datasheet Microchip ATTINY84A-SSFRA1 — Даташит
Производитель | Microchip |
Серия | ATtiny84A |
Модель | ATTINY84A-SSFRA1 |
The high-performance, Microchip's picoPowerВ® 8-bit AVRВ® RISC-based microcontroller combines 8KB ISP flash memory, 512-Byte EEPROM, 512-Byte SRAM, 12 general purpose I/O lines, 32 general purpose working registers, an 2 timers/counters (8-bit/16-bit) with two PWM channels each, internal and external interrupts, 8-channel 10-bit A/D converter, programmable gain stage (1x, 20x) for 12 differential ADC channel pairs, programmable watchdog timer with internal oscillator, internal calibrated oscillator, and four software selectable power saving modes
Datasheet ATtiny24A, ATtiny44A. Appendix A. Specification at 105°C
PDF, 3.3 Мб, Файл опубликован: 1 авг 2011, Страниц: 60
8-bit Microcontroller with 2K/4K Bytes In-System Programmable Flash
Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Appendix B. Specification at 125°C
PDF, 4.5 Мб, Файл опубликован: 1 окт 2013, Страниц: 85
8-bit AVR Microcontroller with 2K/4K/8K Bytes In-System Programmable Flash
Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Complete
PDF, 9.6 Мб, Файл опубликован: 1 июн 2012, Страниц: 286
8-bit Microcontroller with 2K/4K/8K Bytes In-System Programmable Flash
Datasheet Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Summary
PDF, 707 Кб, Файл опубликован: 1 июн 2012, Страниц: 22
, 20MHz SOIC High Grade (+125C) Green | |||
ATTINY84A-SSFRA1 Microchip | 44 ₽ |
Корпус | SOIC |
Количество выводов | 14 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU | 8-bit AVR |
CRC/Scan | No |
EEPROM / HEF | 512 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max 16 Bit Digital Timers | 1 |
Max 8 Bit Digital Timers | 1 |
Max A/D Resolution | 10 bits |
Max. CPU Speed MHz | 20 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 1.8 |
Peripheral Pin Select | No PPS |
Pin count | 14 |
Размер памяти программ | 8 Kbytes |
RAM | 512 bytes |
SPI | 1 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
Zero Cross detect | No |
Серия: ATtiny84A (15)
- Microcontrollers > 8-bit Microcontrollers
ATTINY84ASSFRA1, ATTINY84A SSFRA1
