Datasheet Microchip PIC16F1789-ME2/PF — Даташит
Производитель | Microchip |
Серия | PIC16F1789 |
Модель | PIC16F1789-ME2/PF |
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
![]() 53 предложений от 29 поставщиков Микросхема Микроконтроллер, 28KB Flash, 2KB RAM, 256B EEPROM, 12Bit ADC, 5Bit & 8Bit DAC, PSMC, OPAmp, FastComp, CCP, I2C/SPI, EUSART | |||
PIC16F1789-I/ML Microchip | 222 ₽ | ||
PIC16F1789-E/MV Microchip | 247 ₽ | ||
PIC16F1789-I/PT Microchip | от 473 ₽ | ||
PIC16F1789-E/P Microchip | по запросу |
Корпус | TQFP |
ADC Input | 15 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Emulated EEPROM in Flash | 256 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 100 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 21 including complementary |
Количество компараторов | 4 |
Number of DACs | 4 |
Number of Op Amps | 3 |
PWM Max Resolution | 16 Bits |
Package Width | 14x14x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 40 |
Размер памяти программ | 28 KB |
Programmable Switched Mode Controller | 4 |
SPI | 1 |
SRAM | 2048 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F1789 (25)
- PIC16F1789-E/ML PIC16F1789-E/MV PIC16F1789-E/P PIC16F1789-E/PT PIC16F1789-I/ML PIC16F1789-I/MV PIC16F1789-I/P PIC16F1789-I/PT PIC16F1789-ME2/PF PIC16F1789T-E/MV PIC16F1789T-E/PT PIC16F1789T-I/ML PIC16F1789T-I/MV PIC16F1789T-I/PT PIC16LF1789-E/ML PIC16LF1789-E/MV PIC16LF1789-E/P PIC16LF1789-E/PT PIC16LF1789-I/ML PIC16LF1789-I/MV PIC16LF1789-I/P PIC16LF1789-I/PT PIC16LF1789T-I/ML PIC16LF1789T-I/MV PIC16LF1789T-I/PT
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1789ME2/PF, PIC16F1789 ME2/PF
