Datasheet Microchip PIC16F1788T-E/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1788 |
Модель | PIC16F1788T-E/ML |
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
Микросхема Микроконтроллер 8, MCU 8Bit PIC16 PIC RISC 28KB Flash 2.5V/3.3V/5V 28Pin QFN EP T/R | |||
PIC16F1788T-E/ML Microchip | 118 ₽ | ||
PIC16F1788T-E/ML Microchip | по запросу |
Корпус | QFN |
ADC Input | 11 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Emulated EEPROM in Flash | 256 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 21 including complementary |
Количество компараторов | 4 |
Number of DACs | 4 |
Number of Op Amps | 2 |
PWM Max Resolution | 16 Bits |
Package Width | 6x6x0.9mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 28 |
Размер памяти программ | 28 KB |
Programmable Switched Mode Controller | 4 |
SPI | 1 |
SRAM | 2048 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F1788 (28)
- PIC16F1788-E/ML PIC16F1788-E/MLVAO PIC16F1788-E/SO PIC16F1788-E/SP PIC16F1788-E/SS PIC16F1788-I/ML PIC16F1788-I/SO PIC16F1788-I/SP PIC16F1788-I/SS PIC16F1788T-E/ML PIC16F1788T-E/MLVAO PIC16F1788T-E/SS PIC16F1788T-E/SSVAO PIC16F1788T-I/ML PIC16F1788T-I/SO PIC16F1788T-I/SS PIC16F1788T-I/SSVAO PIC16LF1788-E/ML PIC16LF1788-E/SO PIC16LF1788-E/SP PIC16LF1788-E/SS PIC16LF1788-I/ML PIC16LF1788-I/SO PIC16LF1788-I/SP PIC16LF1788-I/SS PIC16LF1788T-I/ML PIC16LF1788T-I/SO PIC16LF1788T-I/SS
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1788TE/ML, PIC16F1788T E/ML
