Datasheet MAX7400ESA+ - Maxim Даташит ИС ((NW)) — Даташит
Наименование модели: MAX7400ESA+
Купить MAX7400ESA+ на РадиоЛоцман.Цены — от 128 до 2 503 ₽56 предложений от 29 поставщиков Фильтр с переключаемыми конденсаторами, эллиптический, Низких Частот, 8-ой, 1, 4.5 В, 5.5 В, NSOIC | |||
| MAX7400ESA+ Maxim | от 2 503 ₽ | ||
| MAX7400ESA+ | по запросу | ||
| MAX7400ESA-T Maxim | по запросу | ||
| MAX7400ESA-T | по запросу | ||
Производитель: Maxim
Описание: ИС ((NW))
19-4764; Rev 2; 6/99
8th-Order, Lowpass, Elliptic, Switched-Capacitor Filters
General Description
The MAX7400/MAX7403/MAX7404/MAX7407 8th-order, lowpass, elliptic, switched-capacitor filters (SCFs) operate from a single +5V (MAX7400/MAX7403) or +3V (MAX7404/MAX7407) supply.
These devices draw 2mA of supply current and allow corner frequencies from 1Hz to 10kHz, making them ideal for low-power antialiasing and post-DAC filtering applications. They feature a shutdown mode that reduces the supply current to 0.2µA. Two clocking options are available: self-clocking (through the use of an external capacitor) or external clocking for tighter cutoff-frequency control. In addition, an offset adjustment pin (OS) allows for the adjustment of the DC output level. The MAX7400/MAX7404 provide 82dB of stopband rejection and a sharp rolloff with a transition ratio of 1.5. The MAX7403/MAX7407 provide a sharper rolloff with a transition ratio of 1.2, while still delivering 60dB of stopband rejection. T
