Datasheet Linear Technology LTC1693-2CS8#TRPBF — Даташит
СерияLTC1693
МодельLTC1693-2CS8#TRPBF
Высокоскоростные одно-/двойные драйверы N-канальных MOSFET-транзисторов
Datasheet LTC1693
PDF, 270 Кб, Версия: A, Файл закачен: 26 окт 2017, Страниц: 20
High Speed Single/Dual N-Channel MOSFET Drivers
16 предложений от 12 поставщиков
Контролер нагрузки, Driver 1.7A 2Out High and Low Side Inv/Non-Inv 8Pin SOIC N T/R
LTC1693-2CS8#TRPBF
74 ₽
LTC1693-2CS8#TRPBF
164 ₽
LTC1693-2CS8#TRPBF
T-electron
LTC1693-2CS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Demo BoardsDC259A,DC610A
Design ToolsLTspice Model
Экспортный контрольнет
FunctionDual N-Channel MOSFET Driver
Switches2
Vin Max14 В
Vin Range4.5 to 13
  • Load Transient Response Testing for Voltage Regulators &mdash AN104
    PDF, 521 Кб, Файл опубликован: 1 окт 2006
    Semiconductor memory, card readers, microprocessors, discdrives, piezoelectric devices and digitally based systems furnishtransient loads that a voltage regulator must service. Ideally,regulator output is invariant during a load transient. In practice,some variation is encountered and becomes problematic if allowableoperating voltage tolerances are exceeded. This mandatestesting the regulator and its associated support components toverify desired performance under transient loading conditions.Various methods are employable to generate transient loads,allowing observation of regulator response. This application notepresents open and closed loop transient load testing circuitrywith measured performance taken under various conditions.Practical considerations for a memory supply voltage regulatorare reviewed. Four appended sections cover capacitor parasiticsand their effects on load transient response, output capacitor selection,probing techniques and a stabilized transient load tester.
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Secondary Side Dual Output Controller Tightly Regulates Two Isolated Outputs &mdash DN1000
    PDF, 90 Кб, Файл опубликован: 1 дек 2003
  • Unique High Efficiency 12V Converter Operates with Inputs from 6V to 28V &mdash DN233
    PDF, 78 Кб, Файл опубликован: 2 июн 2001
Статьи
  • Single-Inductor, Positive-Output Buck/Boost Converter Uses No Rsense Controller &mdash LT Journal
    PDF, 136 Кб, Файл опубликован: 1 июн 1999
  • Monitor, Control and Protection > High Side Switches & MOSFET Drivers
LTC1693-2CS8TRPBF, LTC1693-2CS8 TRPBF, LTC16932CS8#TRPBF, LTC1693 2CS8#TRPBF
На английском языке: Datasheet Linear Technology LTC1693-2CS8#TRPBF
