Datasheet MAX932ESA+ - Maxim Даташит ИС GENERAL PURPOSE COMP сдвоенный 12 мкс SOIC-8 — Даташит
Maxim MAX932ESA+
Наименование модели: MAX932ESA+
46 предложений от 24 поставщиков
MAXIM INTEGRATED PRODUCTS MAX932ESA+ Analog Comparator, Low Voltage, Micropower, 2, 12µs, 2.5V to 11V, ± 1.25V to ± 5.5V, NSOIC, 8Pins...
727GS
MAX932ESA
Maxim
от 40 ₽
MAX932ESA-TG068
Maxim
51 ₽
MAX932ESA+
Maxim
366 ₽
MAX932ESA
Maxim
Производитель: Maxim
Описание: ИС GENERAL PURPOSE COMP сдвоенный 12 мкс SOIC-8
data sheetСкачать Data Sheet
19-0194; Rev 1; 2/97
Ultra Low-Power, Low-Cost Comparators with 2% Reference
_______________General Description
The MAX931-MAX934 single, dual, and quad micropower, low-voltage comparators plus an on-board 2% accurate reference feature the lowest power consumption available.
These comparators draw less than 4µA supply current over temperature (MAX931), and include an internal 1.182V ±2% voltage reference, programmable hysteresis, and TTL/CMOS outputs that sink and source current. Ideal for 3V or 5V single-supply applications, the MAX931-MAX934 operate from a single +2.5V to +11V supply (or a ±1.25V to ±5V dual supply), and each comparator's input voltage range extends from the negative supply rail to within 1.3V of the positive supply. The MAX931-MAX934's unique output stage continuously sources as much as 40mA. And by eliminating powersupply glitches that commonly occur when comparators change logic states, the MAX931-MAX934 minimize parasitic feedback, which makes them easier to use
На английском языке: Datasheet MAX932ESA+ - Maxim IC GENERAL PURPOSE COMP DUAL 12 µs SOIC-8
