Datasheet Linear Technology LTM4650AIY-1#PBF — Даташит
Серия | LTM4650A-1 |
Модель | LTM4650AIY-1#PBF |
Dual 25A or Single 50A DC/DC µModule Regulator with 1% DC Accuracy
Datasheet LTM4650A-1
PDF, 1.3 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 36
Dual 25A or Single 50A DC/DC μModule Regulator with 1% DC Accuracy
![]() 28 предложений от 12 поставщиков Интегрированные Локализованные к Нагрузке Регулируемые DC - DC Преобразователи | |||
LTM4650AIY-1#PBF Analog Devices | от 103 ₽ | ||
LTM4650AIY-1#PBF Analog Devices | от 2 360 ₽ | ||
LTM4650AIY-1#PBF Linear Technology | от 16 122 ₽ | ||
LTM4650AIY-1#PBF Analog Devices | по запросу |
Корпус | 16mm × 16mm × 5.01mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1523 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2603A-B |
Design Tools | LTspice Model,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Internal Heat Sink, Differential Remote Sense, PolyPhase, Resistor Set Frequency, External Synchronization, Temperature Monitor, Burst Mode, Power Good |
Тактовая частота | 500 kHz |
Frequency Adjust Range | 400kHz - 780kHz |
Frequency Sync Range | 400kHz - 780kHz |
Integrated Inductor | да |
Ishutdown | 35 мкА |
Isupply | 4.5 мА |
Max Phases | 2, 4, 6, 8, 10, 12 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 25 A |
Output Current 2 | 25 A |
Polyphase | да |
Switch Current | 25 A |
Switch Current 2 | 25 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 16 В |
Vin Min | 4.5 В |
Vout Max | 5.5 В |
Vout Max 2 | 5.5 В |
Vout Maximum | 5.5V |
Vout Min | 0.6 В |
Vout Min 2 | 0.6 В |
Vref Accuracy Over Temp | 1 % |
Серия: LTM4650A-1 (3)
- LTM4650AEY-1#PBF LTM4650AIY-1 LTM4650AIY-1#PBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4650AIY-1PBF, LTM4650AIY-1 PBF, LTM4650AIY1#PBF, LTM4650AIY 1#PBF
