Datasheet Linear Technology LTM4650IY-1B#PBF — Даташит
Серия | LTM4650-1 |
Модель | LTM4650IY-1B#PBF |
Dual 25A or Single 50A µModule Regulator with 0.8% DC and 3% Transient Accuracy
Datasheet LTM4650-1
PDF, 673 Кб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 36
![]() 19 предложений от 11 поставщиков DC DC CNVRTR 0.6-1.8V 0.6-1.8V / Non-Isolated PoL Module DC DC Converter 2 Output 0.6 ~ 1.8V 0.6 ~ 1.8V 25A,... | |||
LTM4650IY-1B Analog Devices | от 34 ₽ | ||
LTM4650IY-1B Linear Technology | от 2 839 ₽ | ||
LTM4650IY-1B Analog Devices | 5 832 ₽ | ||
LTM4650IY-1B Analog Devices | 9 107 ₽ |
Корпус | 16mm × 16mm × 5.01mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1523 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2455A-A,DC2378A-B,DC2455A-B,DC2455A-C,DC2479A-B |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Internal Heat Sink, Differential Remote Sense, PolyPhase, Resistor Set Frequency, External Synchronization, Temperature Monitor, Burst Mode, Power Good |
Тактовая частота | 500 kHz |
Frequency Adjust Range | 400kHz - 780kHz |
Frequency Sync Range | 400kHz - 780kHz |
Integrated Inductor | да |
Ishutdown | 50 мкА |
Isupply | 4 мА |
Max Phases | 2, 4, 6, 8, 10, 12 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 25 A |
Output Current 2 | 25 A |
Polyphase | да |
Switch Current | 25 A |
Switch Current 2 | 25 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Vin Max | 15 В |
Vin Min | 4.5 В |
Vout Max | 1.8 В |
Vout Maximum | 1.8V |
Vout Min | 0.6 В |
Vref Accuracy Over Temp | 1 % |
Серия: LTM4650-1 (6)
- LTM4650EY-1A#PBF LTM4650EY-1B#PBF LTM4650IY-1A LTM4650IY-1A#PBF LTM4650IY-1B LTM4650IY-1B#PBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4650IY-1BPBF, LTM4650IY-1B PBF, LTM4650IY1B#PBF, LTM4650IY 1B#PBF
