Datasheet Linear Technology LTC3219EUD#PBF — Даташит
СерияLTC3219
МодельLTC3219EUD#PBF
Универсальный девятиканальный светодиодный драйвер 250 мА
LTC3219 - 250mA Universal Nine Channel LED Driver
PDF, 213 Кб, Версия: A, Файл закачен: 27 сен 2017
32 предложений от 17 поставщиков
LED Driver IC 9 Output DC DC Regulator Switched Capacitor (Charge Pump) I2C Dimming 28mA 20-QFN (3x3)
LTC3219EUD#PBF
99 ₽
IC Home
LTC3219EUD#PBF
445 ₽
LTC3219EUD#PBF
от 576 ₽
МосЧип
LTC3219EUD#PBF
Корпус3x3 QFN-20
Код корпусаUD
Индекс корпуса05-08-1720
Demo BoardsDC1055A
Экспортный контрольнет
Основные особенностиI2C Control
Тактовая частота850 kHz
Ishutdown.1 мкА
Isupply.4 мА
Max Number of LEDs9 (parallel)
Monolithicда
Количество выходов9
Рабочий диапазон температурот 0 до 85 °C
Выходной ток0.25 A
Synchronousнет
TopologyCharge Pump, LED Driver
Vin Max5.5 В
Vin Min2.9 В
Vout Max5.5 В
  • LTC3219 User &mdash AN111
    PDF, 86 Кб, Файл опубликован: 26 июл 2007
    The LTC3219 is a 250mA LED driver which illuminates 9 Universal LEDs (ULEDs). The ULEDs are considered universal because they may be individually turned on or off, set in general purpose output (GPO) mode, set to blink at a selected on-time and period, or gradate on and off at a selected gradation rate. This device also has an external enable (ENU) pin that may be used to blink, gradate, or turn on/off the LEDs without using the I2C bus. This may be useful if the microprocessor is in sleep or standby mode. If used properly, these features may save valuable memory space, programming time, and reduce I2C traffic.
Design Notes
  • Tiny Universal LED Driver Can Gradate, Blink or Turn On Nine Individual LEDs with Minimal External Control &mdash DN422
    PDF, 97 Кб, Файл опубликован: 28 июл 2007
Серия: LTC3219 (2)
  • Power Management > Inductorless (Charge Pump) DC/DC Converters > Inductorless (Charge Pump) LED Drivers
LTC3219EUDPBF, LTC3219EUD PBF
На английском языке: Datasheet Linear Technology LTC3219EUD#PBF
