Datasheet Linear Technology LTC3862IUH-2#PBF — Даташит
Серия | LTC3862-2 |
Модель | LTC3862IUH-2#PBF |
Многофазный повышающий контроллер постоянного/постоянного тока в режиме тока
LTC3862-2 - Multi-Phase Current Mode Step-Up DC/DC Controller
PDF, 896 Кб, Версия: A, Файл закачен: 24 сен 2017
![]() 35 предложений от 16 поставщиков LTC3862-2 - Multi-Phase Current Mode Step-Up DC-DC Controller; Package: QFN; Pins: 24; Temperature Range: -40℃ to 85℃ | |||
LTC3862IUH-2#PBF Analog Devices | 293 ₽ | ||
LTC3862IUH-2#TRPBF Analog Devices | 480 ₽ | ||
LTC3862IUH-2#PBF Analog Devices | 987 ₽ | ||
LTC3862IUH-2#PBF Analog Devices | от 1 094 ₽ |
Корпус | 5x5 QFN-24 |
Код корпуса | UH |
Индекс корпуса | 05-08-1747 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC1891A,DC2006A-A,DC2006A-B |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | PolyPhase, Resistor Set Frequency, External Synchronization |
Тактовая частота | 500kHz kHz |
Frequency Adjust Range | 75kHz - 500kHz |
Frequency Sync Range | 50kHz - 650kHz |
Integrated Inductor | нет |
Ishutdown | 30 мкА |
Isupply | 1.8 мА |
Max Phases | 2, 3, 4, 6, 12 |
Monolithic | нет |
Количество выходов | 1 |
Polyphase | да |
Sense Resistor | Rsense |
Switch Current | 60 A |
Synchronous | нет |
Topology | Boost, Sepic |
Vin Max | 36 В |
Vin Min | 5.5 В |
Vin Min Startup | 5.5 В |
Vout Max | 350 В |
Vout Maximum | 9V and higher |
Vout Min | 1.223 В |
Vswitch Max | 350 В |
Серия: LTC3862-2 (18)
- LTC3862EFE-2#PBF LTC3862EFE-2#TRPBF LTC3862EGN-2#PBF LTC3862EGN-2#TRPBF LTC3862EUH-2#PBF LTC3862EUH-2#TRPBF LTC3862HFE-2#PBF LTC3862HFE-2#TRPBF LTC3862HGN-2#PBF LTC3862HGN-2#TRPBF LTC3862HUH-2#PBF LTC3862HUH-2#TRPBF LTC3862IFE-2#PBF LTC3862IFE-2#TRPBF LTC3862IGN-2#PBF LTC3862IGN-2#TRPBF LTC3862IUH-2#PBF LTC3862IUH-2#TRPBF
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
LTC3862IUH-2PBF, LTC3862IUH-2 PBF, LTC3862IUH2#PBF, LTC3862IUH 2#PBF
