Datasheet Linear Technology LTC3851A — Даташит
СерияLTC3851A
Контроллер синхронного понижающего импульсного регулятора
Datasheet LTC3851A
PDF, 445 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 30
Synchronous Step-Down Switching Regulator Controller
Dual, 2-Phase Synchronous Step-Down DC/DC Controllers
LTC3851A-1 : 4.5-14Vin 1.5Vout@15A
ТаймЧипс
LTC3851A
LifeElectronics
LTC3851A-1
LTC3851AEGN#PBFLTC3851AEGN#TRPBFLTC3851AEMSE#PBFLTC3851AEMSE#TRPBFLTC3851AEUD#PBFLTC3851AEUD#TRPBFLTC3851AHMSE#PBFLTC3851AHMSE#TRPBFLTC3851AIGN#PBFLTC3851AIGN#TRPBFLTC3851AIMSE#PBFLTC3851AIMSE#TRPBFLTC3851AIUD#PBFLTC3851AIUD#TRPBFLTC3851AMPMSE#PBFLTC3851AMPMSE#TRPBF
N12345678910111213141516
КорпусSSOP-16
Габаритный чертеж корпуса
SSOP-16
MS-16E
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
SSOP-16
SSOP-16
MS-16E
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
Код корпусаGNGNMSEMSEUDUDMSEMSEGNGNMSEMSEUDUDMSEMSE
Индекс корпуса05-08-1641 (GN16)05-08-1641 (GN16)05-08-166705-08-166705-08-169105-08-169105-08-166705-08-166705-08-1641 (GN16)05-08-1641 (GN16)05-08-166705-08-166705-08-169105-08-169105-08-166705-08-1667
Количество выводов16161616161616161616161616161616
Parameters / ModelsLTC3851AEGN#PBFLTC3851AEGN#TRPBFLTC3851AEMSE#PBFLTC3851AEMSE#TRPBFLTC3851AEUD#PBFLTC3851AEUD#TRPBFLTC3851AHMSE#PBFLTC3851AHMSE#TRPBFLTC3851AIGN#PBFLTC3851AIGN#TRPBFLTC3851AIMSE#PBFLTC3851AIMSE#TRPBFLTC3851AIUD#PBFLTC3851AIUD#TRPBFLTC3851AMPMSE#PBFLTC3851AMPMSE#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-ADC1432A-A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst ModeDCR Current Sense, Resistor Set Frequency, External Synchronization, Tracking, Burst Mode
Тактовая частота, kHz750750750750750750750750750750750750750750750750
Frequency Adjust Range250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz
Frequency Sync Range250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА25252525252525252525252525252525
Isupply, мА1.21.21.21.21.21.21.21.21.21.21.21.21.21.21.21.2
Max Phases1111111111111111
Monolithicнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Количество выходов1111111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A25252525252525252525252525252525
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Sense ResistorRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCR
Switch Current, A25252525252525252525252525252525
Synchronousдададададададададададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В38383838383838383838383838383838
Vin Min, В4444444444444444
Vout Max, В5.55.55.55.55.55.55.55.55.55.55.55.55.55.55.55.5
Vout Maximum5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V5.5V
Vout Min, В0.80.80.80.80.80.80.80.80.80.80.80.80.80.80.80.8
Vref Accuracy Over Temp, %1111111111111111
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Modeling and Loop Compensation Design of Switching Mode Power Supplies &mdash AN149
    PDF, 1.4 Мб, Файл опубликован: 23 мар 2015
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3851A
Публикации по теме
