Datasheet Linear Technology LTC3805-5 — Даташит
СерияLTC3805-5
Регулируемая частота тока Режим обратного хода/повышения/SEPIC Контроллер постоянного/постоянного тока
Datasheet LTC3805-5
PDF, 265 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 20
Adjustable Frequency Current Mode Flyback/Boost/SEPIC DC/DC Controller
LTC3805-5: 5-30Vin 12Vout@3A
LTC3805EDD-5#PBFLTC3805EDD-5#TRPBFLTC3805EMSE-5#PBFLTC3805EMSE-5#TRPBFLTC3805HMSE-5#PBFLTC3805HMSE-5#TRPBFLTC3805IDD-5#PBFLTC3805IDD-5#TRPBFLTC3805IMSE-5#PBFLTC3805IMSE-5#TRPBFLTC3805MPMSE-5#PBFLTC3805MPMSE-5#TRPBF
N123456789101112
Корпус3x3 DFN-10
Габаритный чертеж корпуса
3x3 DFN-10
MS-10E
MS-10E
MS-10E
MS-10E
3x3 DFN-10
3x3 DFN-10
MS-10E
MS-10E
MS-10E
MS-10E
Код корпусаDDDDMSEMSEMSEMSEDDDDMSEMSEMSEMSE
Индекс корпуса05-08-169905-08-169905-08-166405-08-166405-08-166405-08-166405-08-169905-08-169905-08-166405-08-166405-08-166405-08-1664
Количество выводов101010101010101010101010
Parameters / ModelsLTC3805EDD-5#PBFLTC3805EDD-5#TRPBFLTC3805EMSE-5#PBFLTC3805EMSE-5#TRPBFLTC3805HMSE-5#PBFLTC3805HMSE-5#TRPBFLTC3805IDD-5#PBFLTC3805IDD-5#TRPBFLTC3805IMSE-5#PBFLTC3805IMSE-5#TRPBFLTC3805MPMSE-5#PBFLTC3805MPMSE-5#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576ADC1311A-B,DC1576A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set FrequencyExternal Synchronization, Resistor Set Frequency
Тактовая частота, kHz700700700700700700700700700700700700
Frequency Adjust Range70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz
Frequency Sync Range70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz70kHz - 700kHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА404040404040404040404040
Isupply, мА0.360.360.360.360.360.360.360.360.360.360.360.36
Max Phases111111111111
Monolithicнетнетнетнетнетнетнетнетнетнетнетнет
Количество выходов111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнет
Sense ResistorRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsense
Switch Current, A101010101010101010101010
Synchronousнетнетнетнетнетнетнетнетнетнетнетнет
TopologyFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, BoostFlyback, Boost
Vin Max, В757575757575757575757575
Vin Min, В4.54.54.54.54.54.54.54.54.54.54.54.5
Vin Min Startup, В4.54.54.54.54.54.54.54.54.54.54.54.5
Vout Max, В757575757575757575757575
Vout Maximum75V75V75V75V75V75V75V75V75V75V75V75V
Vout Min, В0.80.80.80.80.80.80.80.80.80.80.80.8
Vswitch Max, В757575757575757575757575
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
Design Notes
  • Negative Buck Converter with Short-Circuit Protection and Shutdown &mdash DN1022
    PDF, 109 Кб, Файл опубликован: 8 сен 2011
  • Buck Converter Eases the Task of Designing Auxiliary Low Voltage Negative Rails &mdash DN458
    PDF, 76 Кб, Файл опубликован: 8 янв 2009
  • Power Management > Switching Regulator > SEPIC Regulators | Flyback, Forward and Isolated Controllers
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3805-5
