Datasheet Linear Technology LTC3604 — Даташит
СерияLTC3604
Монолитный синхронный понижающий стабилизатор 2,5 А, 15 В
Datasheet LTC3604
PDF, 394 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 26
2.5A, 15V Monolithic Synchronous Step-Down Regulator
50 предложений от 24 поставщиков
LTC3604EUD#PBF
111 ₽
LTC3604EUD#PBF
от 148 ₽
LTC3604EUD#PBF
от 1 039 ₽
ТаймЧипс
LTC3604EMSE#PBF
LTC3604EMSE#PBFLTC3604EMSE#TRPBFLTC3604EUD#PBFLTC3604EUD#TRPBFLTC3604IMSE#PBFLTC3604IMSE#TRPBFLTC3604IUD#PBFLTC3604IUD#TRPBF
N12345678
КорпусMS-16E
Габаритный чертеж корпуса
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
3x3 QFN-16
3x3 QFN-16
Код корпусаMSEMSEUDUDMSEMSEUDUD
Индекс корпуса05-08-166705-08-166705-08-169105-08-169105-08-166705-08-166705-08-169105-08-1691
Количество выводов1616161616161616
Parameters / ModelsLTC3604EMSE#PBFLTC3604EMSE#TRPBFLTC3604EUD#PBFLTC3604EUD#TRPBFLTC3604IMSE#PBFLTC3604IMSE#TRPBFLTC3604IUD#PBFLTC3604IUD#TRPBF
АрхитектураConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current Mode
Demo BoardsDC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611ADC1610A,DC1611A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Power Good
Тактовая частота, kHz40004000400040004000400040004000
Frequency Adjust Range800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz
Frequency Sync Range800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz800kHz - 4MHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА1414141414141414
Isupply, мА0.30.30.30.30.30.30.30.3
Max Phases11111111
Monolithicдададададададада
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A2.52.52.52.52.52.52.52.5
Polyphaseнетнетнетнетнетнетнетнет
Switch Current, A3.43.43.43.43.43.43.43.4
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В1515151515151515
Vin Min, В3.63.63.63.63.63.63.63.6
Vout Max, В14.5214.5214.5214.5214.5214.5214.5214.52
Vout Maximum0.97Vin0.97Vin0.97Vin0.97Vin0.97Vin0.97Vin0.97Vin0.97Vin
Vout Min, В0.60.60.60.60.60.60.60.6
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
Статьи
  • Two Monolithic DC/DC Converters Take 3.6V-15V Inputs Down to 0.6V at High Frequency, Shrinking Battery-Powered Applications in Everything from Handhelds to Automobiles &mdash LT Journal
    PDF, 829 Кб, Файл опубликован: 15 июл 2011
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LTC3604
Публикации по теме
