Datasheet Linear Technology LT3991 — Даташит
Серия | LT3991 |
Понижающий стабилизатор 55 В, 1,2 А с током покоя 2,8 мкА
Datasheet LT3991, LT3991-3.3, LT3991-5
PDF, 398 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 24
55V, 1.2A Step-Down Regulator with 2.8μA Quiescent Current
52 предложений от 25 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — постоянного тока коммутирующие | |||
LT3991EDD#TRPBF Analog Devices | от 135 ₽ | ||
LT3991IMSE#PBF Analog Devices | 198 ₽ | ||
LT3991EDD#TRPBF Linear Technology | 328 ₽ | ||
LT3991EDDTRPBF | по запросу |
Parameters / Models | LT3991EDD#PBF | LT3991EDD#TRPBF | LT3991EMSE#PBF | LT3991EMSE#TRPBF | LT3991EMSE-3.3#PBF | LT3991EMSE-3.3#TRPBF | LT3991EMSE-5#PBF | LT3991EMSE-5#TRPBF | LT3991IDD#PBF | LT3991IDD#TRPBF | LT3991IMSE#PBF | LT3991IMSE#TRPBF | LT3991IMSE-3.3#PBF | LT3991IMSE-3.3#TRPBF | LT3991IMSE-5#PBF | LT3991IMSE-5#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A | DC1526A |
Design Tools | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization | Burst Mode, Resistor Set Frequency, External Synchronization |
Тактовая частота, kHz | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 |
Frequency Adjust Range | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz | 200kHz - 2MHz |
Frequency Sync Range | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz | 250kHz - 2MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Isupply, мА | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 | 55 |
Vin Min, В | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 | 4.3 |
Vout Max, В | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 |
Vout Maximum | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V | 30V |
Vout Min, В | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 | 1.19 |
Vref Accuracy Over Temp, % | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 |
LT3991EDD#PBF | LT3991EDD#TRPBF | LT3991EMSE#PBF | LT3991EMSE#TRPBF | LT3991EMSE-3.3#PBF | LT3991EMSE-3.3#TRPBF | LT3991EMSE-5#PBF | LT3991EMSE-5#TRPBF | LT3991IDD#PBF | LT3991IDD#TRPBF | LT3991IMSE#PBF | LT3991IMSE#TRPBF | LT3991IMSE-3.3#PBF | LT3991IMSE-3.3#TRPBF | LT3991IMSE-5#PBF | LT3991IMSE-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- 1.2A Buck Converters Draw Only 2.8µA When Regulating Zero Load, Accept 38VIN or 55VIN &mdash LT JournalPDF, 955 Кб, Файл опубликован: 1 дек 2009Выписка из документа
Серия: LT3991 (16)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
