Datasheet Linear Technology LT1534IS-1#TRPBF — Даташит
Серия | LT1534-1 |
Модель | LT1534IS-1#TRPBF |
Сверхмалошумящий импульсный регулятор 2А
Datasheet LT1534
PDF, 216 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 16
Ultralow Noise 2A Switching Regulators
![]() 15 предложений от 11 поставщиков , Ultralow Noise 2A Switching Regulator | |||
LT1534IS-1#TRPBF Linear Technology | от 290 ₽ | ||
LT1534IS-1#TRPBF Linear Technology | от 547 ₽ | ||
LT1534IS-1#TRPBF Analog Devices | по запросу | ||
Корпус | SO-16 |
Код корпуса | S |
Индекс корпуса | 05-08-1610 (S16) |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | Low EMI, Adjustable Slew Rate, External Synchronization |
Тактовая частота | 250 kHz |
Frequency Sync Range | 25kHz - 375kHz |
Integrated Inductor | нет |
Ishutdown | 12 мкА |
Isupply | 12 мА |
Monolithic | да |
Количество выходов | 1 |
Polyphase | нет |
Switch Current | 2 A |
Synchronous | нет |
Topology | Boost, Flyback, Sepic |
Vin Max | 23 В |
Vin Min | 2.7 В |
Vout Max | 35 В |
Vout Min | 1.3 В |
Vswitch Max | 35 В |
- High Voltage, Low Noise, DC/DC Converters &mdash AN118PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator conп¬Ѓgurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output п¬Ѓltering methods that are usually impractical.Выписка из документа - Circuitry for Signal Conditioning and Power Conversion &mdash AN75PDF, 508 Кб, Файл опубликован: 1 мар 1999
This publication includes designs for data converters and signal conditioners, transducer circuits, crystal oscillators and power converters. Wideband and micropower circuitry receive special attention. Tutorials on micropower design techniques and parasitic effects of test equipment are included.Выписка из документа
Design Notes
- LT1534 Ultralow Noise Switching Regulator Controls EMI &mdash DN178PDF, 99 Кб, Файл опубликован: 1 апр 1998Выписка из документа
Серия: LT1534-1 (4)
- LT1534CS-1#PBF LT1534CS-1#TRPBF LT1534IS-1#PBF LT1534IS-1#TRPBF
- Power Management > Switching Regulator > Ultralow Noise Regulators
LT1534IS-1TRPBF, LT1534IS-1 TRPBF, LT1534IS1#TRPBF, LT1534IS 1#TRPBF
