Datasheet Linear Technology LT1170HVCT#30PBF — Даташит
СерияLT1170HV
МодельLT1170HVCT#30PBF
Высокоэффективные импульсные регуляторы 100 кГц, 5 А, 2,5 А и 1,25 А
LT1170/LT1171/LT1172 - 100kHz, 5A, 2.5A and 1.25A High Efficiency Switching Regulators
PDF, 339 Кб, Версия: I, Файл закачен: 3 сен 2017
, Conv DC-DC 3V to 60V Step Down/Step Up Single-Out 1.244V to 40V 100W 5-Pin(5+Tab) TO-220 Tube
LT1170HVCT#30PBF
518 ₽
LT1170HVCT#30PBF
528 ₽
IC Home
LT1170HVCT#30PBF
1 160 ₽
LT1170HVCT#30PBF
1 306 ₽
КорпусTO-220
Код корпусаT
Индекс корпуса05-08-1421 (Std)
АрхитектураConstant Frequency Current Mode
Design ToolsLTspice File
Экспортный контрольнет
Основные особенностиExternal Synchronization
Тактовая частота100 kHz
Frequency Sync Range120kHz - 160kHz
Integrated Inductorнет
Ishutdown50 мкА
Isupply6 мА
Monolithicда
Количество выходов1
Polyphaseнет
Switch Current5 A
Synchronousнет
TopologyBoost, Flyback, Sepic
Vin Max60 В
Vin Min3 В
Vin Min Startup3 В
Vout Max60 В
Vout Min1.244 В
Vswitch Max75 В
LT1170 LT1171 LT1171HV LT1172 LT1172HV
  • Illumination Circuitry for Liquid Crystal Displays &mdash AN49
    PDF, 5.3 Мб, Файл опубликован: 23 авг 1992
    Current generation portable computers and instruments utilize backlit liquid crystal displays. The back light requires a highly efficient, high voltage AC source as well as other supply circuitry. AN49 details these circuits and also includes sections on efficiency measurements and instrumentation considerations. A separate section discusses physical and layout considerations for the display.
  • Power Conditioning for Notebook and Palmtop Systems &mdash AN51
    PDF, 260 Кб, Файл опубликован: 3 авг 1992
    Notebook and palmtop systems need a number of voltages developed from a battery. Competitive solutions require small size, high efficiency and light weight. This publication includes circuits for high efficiency 5V and 3.3V switching and linear regulators, back light display drivers and battery chargers. All the circuits are specifically tailored for the requirements outlined above.
  • Techniques for 92% Efficient LCD Illumination &mdash AN55
    PDF, 688 Кб, Файл опубликован: 1 авг 1993
    This publication details several LCD backlight circuits which feature 92% efficiency. Other benefits include low voltage operation, synchronizing capability, higher output power for color displays, and extended dimming range. Extensive coverage of practical issues includes layout problems, multi-lamp displays, safety and reliability concerns and efficiency and photometric measurements. Also included is a review of circuits which did not work along with appropriate commentary.
  • Practical Circuitry for Measurement and Control Problems &mdash AN61
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1994
    This collection of circuits was worked out between June 1991 and July of 1994. Most were designed at customer request or are derivatives of such efforts. Types of circuits include power converters, transducer signal conditioners, amplifiers and signal generators. Specific circuits include low noise amplifiers, high power single cell DC/DC converters, portable high accuracy barometers, a 10mHz 1% accuracy RMS/DC converter, and random noise generators. Appended sections cover noise theory and present a historical perspective of wideband amplifiers.
  • A Fourth Generation of LCD Backlight Technology &mdash AN65
    PDF, 5.9 Мб, Файл опубликован: 1 ноя 1995
    This publication, LTC's fourth effort devoted to LCD backlighting in as many years, treats the subject comprehensively. The text considers lamps, display and layout induced losses, circuitry, efficiency related issues, optimization and measurement techniques. Twelve appended sections cover lamp types, mechanical design, electrical and photometric measurement, layout, circuitry and related topics.
Design Notes
  • Switching Regulator Allows Alkalines to Replace NiCads &mdash DN41
    PDF, 70 Кб, Файл опубликован: 1 ноя 1990
Статьи
  • Positive-to-Negative Converter Powers В–48V Telecom Circuits &mdash LT Journal
    PDF, 230 Кб, Файл опубликован: 1 май 1998
  • Power Management > Switching Regulator > SEPIC Regulators
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
LT1170HVCT30PBF, LT1170HVCT 30PBF
На английском языке: Datasheet Linear Technology LT1170HVCT#30PBF
