Datasheet Linear Technology LT1763MPS8-5#TRPBF — Даташит
СерияLT1763
МодельLT1763MPS8-5#TRPBF
Малошумящие регуляторы малой мощности, LDO, 500 мА
Datasheet LT1763
PDF, 1.2 Мб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 22
500mA, Low Noise, LDO Micropower Regulators
10 предложений от 8 поставщиков
, LDO Regulator Pos 5V 0.5A Automotive 8-Pin SOIC N T/R
LT1763MPS8-5#TRPBF
280 ₽
LT1763MPS8-5#TRPBF
296 ₽
727GS
LT1763MPS8-5#TRPBF
от 706 ₽
LT1763MPS8-5#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Demo BoardsDC368A
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage0.3 В
Экспортный контрольнет
Основные особенностиShutdown
Ishutdown1 мкА
Isupply0.03 мА
Max Junction Temp150 Deg
Количество выходов1
Рабочий диапазон температурот -55 до 125 °C
Выходной ток0.5 A
Выходное напряжениеAdj,1.5, 1.8, 2.5, 3, 3.3, 5
PSRR65 дБ
RMS Noise20 µV
Theta JA40В°C/W (DE), 70В°C/W (S8)
ТипPNP
Vin Max20 В
Vin Min1.8 В
Vout Max20 В
Vout Min1.22 В
  • Minimizing Switching Regulator Residue in Linear Regulator Outputs &mdash AN101
    PDF, 358 Кб, Язык: анг., Файл опубликован: 16 июл 2005, Страниц: 12
    Application Note 101. Linear regulators are commonly employed to post-regulate switching regulator outputs. Benefits include improved stability, accuracy, transient response and lowered output impedance. Ideally, these performance gains would be accompanied by markedly reduced switching regulator generated ripple and spikes. In practice, all linear regulators encounter some difficulty with ripple and spikes, particularly as frequency rises. This publication explains the causes of linear regulators' dynamic limitations and presents board level techniques for improving ripple and spike rejection. A hardware based ripple/spike simulator is presented, enabling rapid breadboard testing under various conditions. Three appendices review ferrite beads, inductor based filters and probing practice for wideband, sub-millivolt signals.
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83
    PDF, 542 Кб, Файл опубликован: 1 мар 2000
    In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.
Design Notes
  • Lowest Noise SOT-23 LDOs Have 20ВµA Quiescent Current, 20ВµVrms Noise &mdash DN220
    PDF, 114 Кб, Файл опубликован: 1 дек 1999
Статьи
  • Dual Regulators Offer Flexibility with Independent Shutdown Control and Adjustable Start-Up Timing &mdash LT Journal
    PDF, 210 Кб, Файл опубликован: 1 май 2004
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1763MPS8-5TRPBF, LT1763MPS8-5 TRPBF, LT1763MPS85#TRPBF, LT1763MPS8 5#TRPBF
На английском языке: Datasheet Linear Technology LT1763MPS8-5#TRPBF
Публикации по теме
