Datasheet Linear Technology LT1389BCS8-5#TRPBF — Даташит
Серия | LT1389 |
Модель | LT1389BCS8-5#TRPBF |
Прецизионный шунтирующий опорный источник напряжения Nanopower
Datasheet LT1389
PDF, 219 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Nanopower Precision Shunt Voltage Reference
![]() 16 предложений от 12 поставщиков Опорный чип напряжения, V-Ref Precision 5V 10mA 8Pin SOIC N T/R | |||
LT1389BCS8-5#TRPBF Analog Devices | 145 ₽ | ||
LT1389BCS8-5#TRPBF Linear Technology | 273 ₽ | ||
LT1389BCS8-5#TRPBF Linear Technology | 303 ₽ | ||
LT1389BCS8-5#TRPBF Linear Technology | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Initial Accuracy | 0.075 % |
Low Freq Noise | 100 µVPP |
Min Vin/Vout Differential | Shunt В |
Рабочий диапазон температур | от 0 до 70 °C |
Диапазон выходных токов | Shunt |
Quiescent or Min Shunt Current | 0.6 мкА |
Ref Vout | 5 В |
Series/Shunt | Shunt |
Temp Co | 12 ppm/В°C |
- Circuitry for Signal Conditioning and Power Conversion &mdash AN75PDF, 508 Кб, Файл опубликован: 1 мар 1999
This publication includes designs for data converters and signal conditioners, transducer circuits, crystal oscillators and power converters. Wideband and micropower circuitry receive special attention. Tutorials on micropower design techniques and parasitic effects of test equipment are included.Выписка из документа - Instrumentation Applications for a Monolithic Oscillator: A Clock for All Reasons &mdash AN93PDF, 1.1 Мб, Файл опубликован: 1 фев 2003
Instrumentation applications for a monolithic programmable oscillator are presented in this publication. Circuits include platinum and thermistor based thermometers, an isolated thermometer and three relative humidity signal conditioners. Bipolar and FET input chopper stabilized amplifiers with noise below 45nV (0.1Hz to 10Hz) are detailed. Two clock tunable sine wave generators with settable amplitude appear, as well as a tunable notch filter, an interval generator and an A to D converter. The oscillator's performance is contrasted against other approaches and its interval operation discussed.Выписка из документа
Design Notes
- UL Isolated Self-Powered Sensing &mdash DN204PDF, 80 Кб, Файл опубликован: 3 апр 1999Выписка из документа
Статьи
- Avoid Debugging Cycles in Power Management for FPGA, GPU and ASIC Systems &mdash LT JournalPDF, 3.2 Мб, Файл опубликован: 25 авг 2016Выписка из документа
- 4.5µA Li-Ion Battery Protection Circuit &mdash LT JournalPDF, 114 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- How to Choose a Voltage Reference &mdash LT JournalPDF, 282 Кб, Файл опубликован: 1 мар 2009Выписка из документа
Серия: LT1389 (10)
- Signal Conditioning > Voltage References > Shunt Voltage References | Micropower Voltage References
LT1389BCS8-5TRPBF, LT1389BCS8-5 TRPBF, LT1389BCS85#TRPBF, LT1389BCS8 5#TRPBF
