Datasheet Linear Technology LT1019CS8-10#TRPBF — Даташит
Серия | LT1019CS8-10 |
Модель | LT1019CS8-10#TRPBF |
Справочник по точности
Datasheet LT1019
PDF, 164 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Precision Reference
Precision Reference
![]() 28 предложений от 13 поставщиков Источники Опорного Напряжения | |||
LT1019CS8-10#TRPBF Analog Devices | от 135 ₽ | ||
LT1019CS8-10#TRPBF Analog Devices | 244 ₽ | ||
LT1019CS8-10#TRPBF Analog Devices | 1 017 ₽ | ||
LT1019CS8-10#TRPBF Analog Devices | от 1 500 ₽ |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Экспортный контроль | нет |
Initial Accuracy | 0.2 % |
Line Reg | .5 ppm/V |
Load Reg | .02 ppm/mA |
Low Freq Noise | 25 µVPP |
Min Vin/Vout Differential | 1.1 В |
Рабочий диапазон температур | от 0 до 70 °C |
Диапазон выходных токов | В±10mA |
Quiescent or Min Shunt Current | 650 мкА |
Ref Vout | 10 В |
Series/Shunt | Series |
Temp Co | 5 ppm/В°C |
Vin Max | 40 В |
Vin Min | 10.9 В |
LT1019 LT1019ACN8-10 LT1019ACN8-2.5 LT1019ACN8-4.5 LT1019ACN8-5 LT1019ACS8-2.5 LT1019ACS8-5 LT1019AIS8-2.5 LT1019AIS8-5 LT1019CN8-10 LT1019CN8-2.5 LT1019CN8-4.5 LT1019CN8-5 LT1019CS8-2.5 LT1019CS8-4.5 LT1019CS8-5 LT1019IN8-10 LT1019IN8-2.5 LT1019IN8-4.5 LT1019IN8-5 LT1019IS8-2.5 LT1019IS8-5
- High Voltage, Low Noise, DC/DC Converters &mdash AN118PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator conп¬Ѓgurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output п¬Ѓltering methods that are usually impractical.Выписка из документа - Thermocouple Measurement &mdash AN28PDF, 988 Кб, Файл опубликован: 1 фев 1988
Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.Выписка из документа - Converting Light to Digits: LTC1099 Half Flash 8-Bit A/D Converter Digitizes Photodiode Array &mdash AN33PDF, 703 Кб, Файл опубликован: 2 мар 1989
This application note describes a Linear Technology "Half-Flash" A/D converter, the LTC1099, being connected to a 256 element line scan photodiode array. This technology adapts itself to handheld (i.e., low power) bar code readers, as well as high resolution automated machine inspection applications. - Voltage Reference Circuit Collection &mdash AN42PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques. - Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52PDF, 190 Кб, Файл опубликован: 1 янв 1993
This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.Выписка из документа - Understanding and Applying Voltage References &mdash AN82PDF, 172 Кб, Файл опубликован: 1 ноя 1999
Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.Выписка из документа
Design Notes
- Temperature Measurement Using Data Acquisition Systems &mdash DN5PDF, 77 Кб, Файл опубликован: 1 мар 1989Выписка из документа
Статьи
- How to Choose a Voltage Reference &mdash LT JournalPDF, 282 Кб, Файл опубликован: 1 мар 2009Выписка из документа
Серия: LT1019CS8-10 (2)
- LT1019CS8-10#PBF LT1019CS8-10#TRPBF
- Signal Conditioning > Voltage References > Series Voltage References
LT1019CS8-10TRPBF, LT1019CS8-10 TRPBF, LT1019CS810#TRPBF, LT1019CS8 10#TRPBF
