Datasheet Linear Technology LTC1562AIG#TRPBF — Даташит
Серия | LTC1562 |
Модель | LTC1562AIG#TRPBF |
Универсальный фильтр Active RC Quad с очень низким уровнем шума и искажений
LTC1562 - Very Low Noise, Low Distortion Active RC Quad Universal Filter
PDF, 354 Кб, Версия: A, Файл закачен: 9 авг 2017
![]() 17 предложений от 13 поставщиков , Active Filter Quad Continuous Time UNIV 8th Order 150kHz 20-Pin SSOP T/R | |||
LTC1562AIG#TRPBF Linear Technology | от 374 ₽ | ||
LTC1562AIG#TRPBF Analog Devices | 2 074 ₽ | ||
LTC1562AIG#TRPBF Linear Technology | по запросу | ||
Корпус | SSOP-20 |
Код корпуса | G |
Индекс корпуса | 05-08-1640 (G20) |
Clock Tunable | нет |
Demo Boards | DC266B-B |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Filter Order | 8 order |
Filters Per Package | 4 |
Fo Max | 150 kHz |
Fo Min | 10 kHz |
Fo/Fclk | N/A |
Isupply | 18 мА |
Preconfigured | Universal |
Vs макс. | 10 В |
Vs мин. | 4.75 В |
- Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83PDF, 542 Кб, Файл опубликован: 1 мар 2000
In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.Выписка из документа
Design Notes
- Get 100dB Stopband Attenuation with the LTC1562 Universal Filter Family &mdash DN195PDF, 333 Кб, Файл опубликован: 1 дек 1998Выписка из документа
Статьи
- Universal Continuous-Time Filter Challenges Discrete Designs &mdash LT JournalPDF, 291 Кб, Файл опубликован: 1 фев 1998Выписка из документа
- How to Design High Order Filters with Stopband Notches Using the LTC1562 Operational Filter (Part 2) &mdash LT JournalPDF, 87 Кб, Файл опубликован: 1 фев 1999Выписка из документа
- New Universal Continuous-Time Filter with Extended Frequency Range &mdash LT JournalPDF, 87 Кб, Файл опубликован: 1 фев 1999Выписка из документа
- How to Design High Order Filters with Stopband Notches Using the LTC1562 Quad Operational Filter (Part 1) &mdash LT JournalPDF, 293 Кб, Файл опубликован: 1 май 1998Выписка из документа
- Sharp Gain Roll-Offs Using the LTC1562 Quad Operational Filter IC (Part 3) &mdash LT JournalPDF, 178 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
- Performance Verification of Low Noise, Low Dropout Regulators &mdash LT JournalPDF, 1.2 Мб, Файл опубликован: 1 сен 2000Выписка из документа
Серия: LTC1562 (9)
- Signal Conditioning > Filters > Filter Building Blocks
LTC1562AIGTRPBF, LTC1562AIG TRPBF
