Datasheet Linear Technology LT1721IGN#PBF — Даташит
СерияLT1721
МодельLT1721IGN#PBF
Четырехканальные, 4,5 нс, однополярные компараторы 3 В / 5 В с выходами Rail-to-Rail
Datasheet LT1720, LT1721
PDF, 274 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 28
Dual/Quad, 4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs
31 предложений от 20 поставщиков
Dual/Quad, 4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs | IC COMP R-RINOUT QUAD 16-SSOP
LT1721IGN#TRPBF
226 ₽
IC Home
LT1721IGN#TRPBF
669 ₽
LT1721IGN#TRPBF
1 225 ₽
ЭИК
LT1721IGN#PBF
от 1 814 ₽
КорпусSSOP-16
Код корпусаGN
Индекс корпуса05-08-1641 (GN16)
Количество каналов4
Design ToolsLTspice File
Экспортный контрольнет
Основные особенностиRail-to-Rail Out
HysteresisNone
Isupply4 мА
Output Rise/Fall Time2.5, 2.2 нс
Prop Delay0.0045 µs
Separate O/P SupplyNone
Диапазон напряжения питания2.7V to 6V
Vos1 мВ
Vs макс.6 В
Vs мин.2.7 В
LT1720 LT1720
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
  • Signal Conditioning > Comparators > High Speed Comparators
LT1721IGNPBF, LT1721IGN PBF
На английском языке: Datasheet Linear Technology LT1721IGN#PBF
