Клеммные колодки Keen Side
Datasheet Linear Technology LT1394CMS8#TRPBF — Даташит
СерияLT1394
МодельLT1394CMS8#TRPBF
7 нс, маломощный, однополярный, компаратор с датчиком заземления
Datasheet LT1394
PDF, 228 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 16
7ns, Low Power, Single Supply, Ground-Sensing Comparator
Микросхема Компаратор, Comparator Single ±6V/12V 8Pin MSOP T/R
LT1394CMS8#TRPBF
199 ₽
LT1394CMS8#TRPBF
245 ₽
LT1394CMS8#TRPBF
422 ₽
МосЧип
LT1394CMS8#TRPBF
КорпусMS-8
Код корпусаMS8
Индекс корпуса05-08-1660
Количество каналов1
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенностиOutput Latch
HysteresisNone
Isupply8.5 мА
Output Rise/Fall Time2, 2 нс
Prop Delay0.007 µs
Separate O/P SupplyNone
Диапазон напряжения питания4.5V to В±5V
Vos0.8 мВ
Vs макс.10 В
Vs мин.4.5 В
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • A Seven-Nanosecond Comparator for Single Supply Operation &mdash AN72
    PDF, 882 Кб, Файл опубликован: 1 май 1998
    AN72 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section uses the 7ns LT1394 in V-to-F converters, crystal oscillators, clock skew generators, triggers, sampling configurations and a nanosecond pulse stretcher. Appendices cover related topics.
  • 30 Nanosecond Settling Time Measurement for a Precision Wideband Amplifier &mdash AN79
    PDF, 624 Кб, Файл опубликован: 5 сен 1999
    AN79 modifies methods presented in AN74, permitting verification of 30 nanosecond amplifier settling times to 0.1% resolution. The sampling-based technique used is detailed and results presented. Appendices cover oscilloscope overdrive issues, construction of a subnanosecond rise time pulse generator, amplifier compensation, circuit construction and calibration procedures.
  • Low Noise Varactor Biasing with Switching Regulators: Vanquishing Villainous Vitiators Vis-Г -Vis Vital Varactors &mdash AN85
    PDF, 490 Кб, Файл опубликован: 1 авг 2000
    Telecommunication, satellite links and set-top boxes all require tuning a high frequency oscillation. The actual tuning element, a varactor diode, requires high voltage bias for operation. The high voltage bias must be free of noise to prevent unwanted oscillator outputs. This publication details a method for generating noise free high voltage from low voltage inputs using switching regulators. Spurious oscillator outputs are below -90dBc. Suggested circuit and layout information is included. Appendices cover varactor diode theory and performance verification techniques.
Design Notes
  • A Seven Nanosecond Comparator for Single-Supply Operation &mdash DN185
    PDF, 86 Кб, Файл опубликован: 1 авг 1998
  • Rail-to-Rail I/O and 2.4V Operation Allow UltraFast Comparators to be Used on Low Voltage Supplies &mdash DN248
    PDF, 105 Кб, Файл опубликован: 1 янв 2001
Статьи
  • New UltraFast Comparators: Rail-to-Rail Inputs and 2.4V Operation Allow Use on Low Supplies &mdash LT Journal
    PDF, 194 Кб, Файл опубликован: 1 фев 2001
  • A 7ns, 6mA, Single-Supply Comparator Fabricated on Linear &mdash LT Journal
    PDF, 271 Кб, Файл опубликован: 1 май 1998
  • A 4.5ns, 4mA, Single-Supply, Dual Comparator Optimized for 3V/5V Operation &mdash LT Journal
    PDF, 287 Кб, Файл опубликован: 1 ноя 1998
  • Signal Conditioning > Comparators > High Speed Comparators
LT1394CMS8TRPBF, LT1394CMS8 TRPBF
На английском языке: Datasheet Linear Technology LT1394CMS8#TRPBF
