Datasheet Linear Technology LT6552IDD#TRPBF — Даташит
СерияLT6552
МодельLT6552IDD#TRPBF
Усилитель разности видеосигналов с однополярным питанием 3,3 В
Datasheet LT6552
PDF, 364 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
3.3V Single Supply Video Difference Amplifier
Микросхема Видеоусилитель, Video Amp Single 12.6V Automotive 8Pin DFN EP
LT6552IDD#TRPBF
66 ₽
LT6552IDD#TRPBF
163 ₽
727GS
LT6552IDD#TRPBF
от 2 752 ₽
LT6552IDD#TRPBF
Корпус3x3 DFN-8
Код корпусаDD
Индекс корпуса05-08-1698
Av Min Stable2 V/V
CMRR83 дБ
Количество каналов1
Cload1000 пФ
Demo BoardsDC815A,DC417B
Design ToolsLTspice Model
Enoise Density55 нВ/rtГц
Экспортный контрольнет
GBW75 МГц
Точность коэффициента усиления1 %
HD2-90 dBc
HD3-84 dBc
Ibias20 мкА
Inoise0.7 пА/rtГц
Iout50 мА
Isupply12.5 мА
PSRR54 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outда
SR600 В/мс
Shutdownда
Single Supplyда
Ts (0.1%)35 нс
ТипVFB
Voh (from V+)0.125 В
Vol (from V-)0.008 В
Vos5 мВ
Vos TC40 мВ/C
Vs макс.12.6 В
Vs мин.3 В
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Video Difference Amplifier Brings Versatility to Low Voltage Applications &mdash DN343
    PDF, 88 Кб, Файл опубликован: 1 авг 2004
Статьи
  • Video Instrumentation Amplifier Easily Extracts Clean Video Signals from Noisy Environments &mdash LT Journal
    PDF, 2.7 Мб, Файл опубликован: 25 мар 2005
  • Twisted-Pair Transmission of Closed-Circuit Video Made Easy &mdash LT Journal
    PDF, 239 Кб, Файл опубликован: 1 фев 2004
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | High Speed Amplifiers (GBW > 50MHz) | Rail-to-Rail Amplifiers
  • Signal Conditioning > Amplifiers > Video Functions
LT6552IDDTRPBF, LT6552IDD TRPBF
На английском языке: Datasheet Linear Technology LT6552IDD#TRPBF
Публикации по теме
