Источники питания Keen Side
Datasheet Linear Technology LT6203 — Даташит
СерияLT6203
Два 100-мегагерцовых, Rail-to-Rail входа и выхода, сверхнизкий уровень шума 1,9 нВртГц, маломощные операционные усилители
Datasheet LT6202, LT6203, LT6204
PDF, 1.7 Мб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 28
Quad 100MHz, Rail-to-Rail Input and Output, Ultralow 1.9nV√Hz Noise, Low Power Op Amps
47 предложений от 25 поставщиков
LT6203CDD#TRPBF
от 120 ₽
727GS
LT6203CDD#TRPBF
от 125 ₽
Контест
LT6203CS8
1 252 ₽
LT6203IDD#TRPBF
LT6203CDD#PBFLT6203CDD#TRPBFLT6203CMS8#PBFLT6203CMS8#TRPBFLT6203CS8#PBFLT6203CS8#TRPBFLT6203HMS8#PBFLT6203HMS8#TRPBFLT6203IDD#PBFLT6203IDD#TRPBFLT6203IMS8#PBFLT6203IMS8#TRPBFLT6203IS8#PBFLT6203IS8#TRPBF
N1234567891011121314
Корпус3x3 DFN-8
Габаритный чертеж корпуса
3x3 DFN-8
MS-8
MS-8
SO-8
SO-8
MS-8
MS-8
3x3 DFN-8
3x3 DFN-8
MS-8
MS-8
SO-8
SO-8
Код корпусаDDDDMS8MS8S8S8MS8MS8DDDDMS8MS8S8S8
Индекс корпуса05-08-169805-08-169805-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-166005-08-166005-08-169805-08-169805-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)
Количество выводов88888888888888
Parameters / ModelsLT6203CDD#PBFLT6203CDD#TRPBFLT6203CMS8#PBFLT6203CMS8#TRPBFLT6203CS8#PBFLT6203CS8#TRPBFLT6203HMS8#PBFLT6203HMS8#TRPBFLT6203IDD#PBFLT6203IDD#TRPBFLT6203IMS8#PBFLT6203IMS8#TRPBFLT6203IS8#PBFLT6203IS8#TRPBF
Av Min Stable, V/V11111111111111
Avol, дБ4646464646464646464646464646
CMRR, дБ8585858585858585858585858585
Количество каналов22222222222222
Cload, пФ10001000100010001000100010001000100010001000100010001000
Demo BoardsDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-CDC599A,DC1925A-A,DC1925A-B,DC1925A-C
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Enoise 1/f Corner, Hz500500500500500500500500500500500500500500
Enoise Density, нВ/rtГц1.91.91.91.91.91.91.91.91.91.91.91.91.91.9
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнет
GBW, МГц100100100100100100100100100100100100100100
Ibias, нА13001300130013001300130013001300130013001300130013001300
Inoise, пА/rtГц0.750.750.750.750.750.750.750.750.750.750.750.750.750.75
Inoise 1/f Corner, Hz150150150150150150150150150150150150150150
Ios, мкА0.150.150.150.150.150.150.150.150.150.150.150.150.150.15
Iout, мА4040404040404040404040404040
Isupply, мА2.82.82.82.82.82.82.82.82.82.82.82.82.82.8
LF Enoise, µVPP0.80.80.80.80.80.80.80.80.80.80.80.80.80.8
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Over-the-Topнетнетнетнетнетнетнетнетнетнетнетнетнетнет
PSRR, дБ7474747474747474747474747474
Rail-to-RailBothBothBothBothBothBothBothBothBothBothBothBothBothBoth
Rail-to-Rail Inдададададададададададададада
Rail-to-Rail Outдададададададададададададада
SR, В/мс2525252525252525252525252525
Shutdownнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Single Supplyдададададададададададададада
Ts (0.1%), нс7878787878787878787878787878
ТипVFBVFBVFBVFBVFBVFBVFBVFBVFBVFBVFBVFBVFBVFB
Voh (from V+), В0.040.040.040.040.040.040.040.040.040.040.040.040.040.04
Vol (from V-), В0.0050.0050.0050.0050.0050.0050.0050.0050.0050.0050.0050.0050.0050.005
Vos, мВ0.10.10.10.10.10.10.10.10.10.10.10.10.10.1
Vos TC, мВ/C7.57.57.57.57.57.57.57.57.57.57.57.57.57.5
Vs макс., В12.612.612.612.612.612.612.612.612.612.612.612.612.612.6
Vs мин., В2.52.52.52.52.52.52.52.52.52.52.52.52.52.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT6202 LT6202 LT6204 LT6204
Design Notes
  • 100MHz Op Amp Features Low Noise Rail-to-Rail Performance While Consuming Only 2.5mA &mdash DN308
    PDF, 88 Кб, Файл опубликован: 2 апр 2003
  • Driving a Low Noise, Low Distortion 18-Bit, 1.6Msps ADC &mdash DN494
    PDF, 1.1 Мб, Файл опубликован: 1 авг 2011
Статьи
  • High Speed Low Noise Op Amp Family Challenges Power and Distortion Assumptions with Rail-to-Rail Inputs and Output &mdash LT Journal
    PDF, 181 Кб, Файл опубликован: 9 авг 2004
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Low Noise Amplifiers ( | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
На английском языке: Datasheet Linear Technology LT6203
Публикации по теме
