Datasheet Linear Technology LT1783 — Даташит
Серия | LT1783 |
1,25 МГц, сверхмощная микропроцессор, операционный усилитель на входе и выходе от шины к железной дороге в SOT-23
Datasheet LT1783
PDF, 183 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
1.25MHz, Over-The-Top Micropower, Rail-to-Rail Input and Output Op Amp in SOT-23
![]() 22 предложений от 19 поставщиков 1.25MHz, Over-The-Top Micropower, Rail-to-Rail Input and Output Op Amp in SOT-23 | |||
LT1783CS5 Linear Technology | 11 ₽ | ||
LT1783CS6 Linear Technology | 112 ₽ | ||
LT1783IS5 Linear Technology | по запросу | ||
LT1783CS6 Linear Technology | по запросу |
Parameters / Models | LT1783CS5#PBF | LT1783CS5#TRMPBF | LT1783CS5#TRPBF | LT1783CS6#PBF | LT1783CS6#TRMPBF | LT1783CS6#TRPBF | LT1783HS5#PBF | LT1783HS5#TRMPBF | LT1783HS5#TRPBF | LT1783HS6#PBF | LT1783HS6#TRMPBF | LT1783HS6#TRPBF | LT1783IS5#PBF | LT1783IS5#TRMPBF | LT1783IS5#TRPBF | LT1783IS6#PBF | LT1783IS6#TRMPBF | LT1783IS6#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
CMRR, дБ | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 | 3000 |
Demo Boards | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B | DC479A,DC617A,DC417B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Enoise Density, нВ/rtГц | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 | 1.25 |
Ibias, нА | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 |
Inoise, пА/rtГц | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 | 0.14 |
Inoise 1/f Corner, Hz | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 |
Ios, мкА | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 | 0.004 |
Iout, мА | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
Isupply, мА | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 | 0.21 |
LF Enoise, µVPP | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
PSRR, дБ | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Rail-to-Rail | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both |
Rail-to-Rail In | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 | 0.42 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 | 12000 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
VinCM High (from V+), В | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 | -18 |
Voh (from V+), В | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 |
Vol (from V-), В | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 |
Vos, мВ | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 |
Vos TC, мВ/C | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Vs макс., В | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
Vs мин., В | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 |
LT1783CS5#PBF | LT1783CS5#TRMPBF | LT1783CS5#TRPBF | LT1783CS6#PBF | LT1783CS6#TRMPBF | LT1783CS6#TRPBF | LT1783HS5#PBF | LT1783HS5#TRMPBF | LT1783HS5#TRPBF | LT1783HS6#PBF | LT1783HS6#TRMPBF | LT1783HS6#TRPBF | LT1783IS5#PBF | LT1783IS5#TRMPBF | LT1783IS5#TRPBF | LT1783IS6#PBF | LT1783IS6#TRMPBF | LT1783IS6#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- SOT-23 Micropower, Rail to Rail Op Amps Operate with Inputs Above the Positive Supply &mdash DN221PDF, 160 Кб, Файл опубликован: 1 янв 2001Выписка из документа
- Sense Milliamps to Kiloamps and Digitize to 12 Bits &mdash DN227PDF, 73 Кб, Файл опубликован: 1 апр 2001Выписка из документа
- An Autoranging True RMS Converter &mdash DN339PDF, 77 Кб, Файл опубликован: 1 июн 2004Выписка из документа
Статьи
- Boost Converter Drives 1A White LEDs &mdash LT JournalPDF, 86 Кб, Файл опубликован: 1 май 2004Выписка из документа
- SOT-23 Micropower, Rail-to-Rail Op Amps Operate with Inputs above the Positive Supply &mdash LT JournalPDF, 186 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
Серия: LT1783 (18)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Low Power Amplifiers (Is < 1mA/amp) | Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
