Datasheet Linear Technology LT1228IS8#TRPBF — Даташит
СерияLT1228
МодельLT1228IS8#TRPBF
Усилитель с обратной связью по току 100 МГц с управлением усилением постоянного тока
Datasheet LT1228
PDF, 681 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 22
100MHz Current Feedback Amplifier with DC Gain Control
Микросхема Буферный усилитель, IC OPAMP CFA 100MHz 8SO
LT1228IS8#TRPBF
226 ₽
LT1228IS8#TRPBF
340 ₽
LT1228IS8#TRPBF
421 ₽
LT1228IS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Av Min Stable1 V/V
CMRR69 дБ
Количество каналов1
Cload2000 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise Density20 нВ/rtГц
Экспортный контрольнет
GBW100 МГц
HD2-67 dBc
HD3-60 dBc
Ibias0.4 мкА
Inoise1.4 пА/rtГц
Iout65 мА
Isupply9 мА
PSRR80 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR500 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)45 нс
ТипCFA
VinCM High (from V+)1 В
VinCM Low (from V-)1 В
Voh (from V+)0.8 В
Vol (from V-)0.8 В
Vos0.5 мВ
Vos TC10 мВ/C
Vs макс.36 В
Vs мин.4 В
  • High Speed Amplifier Techniques &mdash AN47
    PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
    This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.
  • Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52
    PDF, 190 Кб, Файл опубликован: 1 янв 1993
    This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.
  • Video Circuit Collection &mdash AN57
    PDF, 559 Кб, Файл опубликован: 2 янв 1994
    AN57, the Video Circuit Collection, features a variety of video circuits designed at LTC. The LT1204 70MHz multiplexer is featured in a number of circuits which require excellent video isolation from channel to channel. High speed voltage and current feedback amplifiers are highlighted throughout the section on video processing circuits. There is a section on applying Current Feedback Amplifiers (CFAs) and a number of articles taken from the Linear Technology magazine.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Video Circuits Collection &mdash DN57
    PDF, 79 Кб, Файл опубликован: 1 апр 1992
  • A Broadband Random Noise Generator &mdash DN70
    PDF, 95 Кб, Файл опубликован: 1 май 1993
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Current Feedback Amplifiers | High Voltage Amplifiers (>12V)
  • Signal Conditioning > Amplifiers > Video Functions
LT1228IS8TRPBF, LT1228IS8 TRPBF
На английском языке: Datasheet Linear Technology LT1228IS8#TRPBF
