Клеммные колодки Keen Side
Datasheet Linear Technology LT1223CS8#PBF — Даташит
СерияLT1223
МодельLT1223CS8#PBF
Усилитель с обратной связью по току 100 МГц
Datasheet LT1223
PDF, 258 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
100MHz Current Feedback Amplifier
36 предложений от 19 поставщиков
LT1223CS8#PBF
127 ₽
LT1223CS8#PBF
135 ₽
HXD Co.
LT1223CS8#TR
TradeElectronics
LT1223CS8
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW100 МГц
Av Min Stable1 V/V
Avol74 дБ
CMRR63 дБ
Cload1800 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise 1/f Corner50 Hz
Enoise Density33 нВ/rtГц
Экспортный контрольнет
Inoise2.2 пА/rtГц
Inoise 1/f Corner90 Hz
Iout60 мА
Isupply6 мА
Over-the-Topнет
PSRR80 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR1000 В/мс
Shutdownда
Single Supplyнет
Ts (0.1%)75 нс
ТипCFA
VinCM High (from V+)3 В
VinCM Low (from V-)3 В
Voh (from V+)3 В
Vol (from V-)3 В
Vos1 мВ
Vs макс.36 В
Vs мин.5 В
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • High Speed Amplifier Techniques &mdash AN47
    PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
    This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.
  • Video Circuit Collection &mdash AN57
    PDF, 559 Кб, Файл опубликован: 2 янв 1994
    AN57, the Video Circuit Collection, features a variety of video circuits designed at LTC. The LT1204 70MHz multiplexer is featured in a number of circuits which require excellent video isolation from channel to channel. High speed voltage and current feedback amplifiers are highlighted throughout the section on video processing circuits. There is a section on applying Current Feedback Amplifiers (CFAs) and a number of articles taken from the Linear Technology magazine.
  • A Monolithic Switching Regulator with 100ВµV Output Noise &mdash AN70
    PDF, 1.7 Мб, Язык: анг., Файл опубликован: 1 окт 1997
    This publication details circuitry and applications considerations for the LT1533 low noise switching regulator. Eleven DC/DC converter circuits are presented, some offering <100µV output noise in a 100MHz bandwidth. Tutorial sections detail low noise DC/DC design, measurement, probing and layout techniques, and magnetics selection.
Design Notes
  • A Precision Wideband Current Probe for LCD Backlight Measurement &mdash DN101
    PDF, 93 Кб, Файл опубликован: 1 апр 1995
  • Current Feedback Amplifier Do's and Don'ts &mdash DN46
    PDF, 167 Кб, Файл опубликован: 1 апр 1991
  • High Frequency Amplifier Evaluation Board &mdash DN50
    PDF, 121 Кб, Файл опубликован: 1 янв 1991
  • Video Circuits Collection &mdash DN57
    PDF, 79 Кб, Файл опубликован: 1 апр 1992
Серия: LT1223 (3)
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Current Feedback Amplifiers | High Voltage Amplifiers (>12V)
LT1223CS8PBF, LT1223CS8 PBF
На английском языке: Datasheet Linear Technology LT1223CS8#PBF
Публикации по теме
