Datasheet Linear Technology LT1013ACN8#PBF — Даташит
СерияLT1013
МодельLT1013ACN8#PBF
Двойной прецизионный операционный усилитель
Datasheet LT1013, LT1014
PDF, 573 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 26
Dual/Quad Precision Op Amps
44 предложений от 19 поставщиков
LT1013ACN8#PBF
162 ₽
Триема
LT1013ACN8 DIP8 Linear Technology
225 ₽
727GS
LT1013ACN8
от 364 ₽
LT1013ACN8#PBF
825 ₽
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Количество каналов2
Частота единичного усиления GBW0.8 МГц
Av Min Stable1 V/V
Avol78 дБ
CMRR117 дБ
Cload100 пФ
Design ToolsLTspice Model
Enoise 1/f Corner2 Hz
Enoise Density22 нВ/rtГц
Экспортный контрольнет
Ibias12 нА
Inoise0.07 пА/rtГц
Inoise 1/f Corner95 Hz
Ios0.00000015 мкА
Iout25 мА
Isupply0.35 мА
LF Enoise0.55 µVPP
Over-the-Topнет
PSRR120 дБ
Rail-to-RailIn to V-
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR0.4 В/мс
Shutdownнет
Single Supplyда
ТипVFB
VinCM High (from V+)1.2 В
VinCM Low (from V-)-0.3 В
Voh (from V+)1 В
Vol (from V-)1 В
Vos0.04 мВ
Vos TC0.3 мВ/C
Vs макс.44 В
Vs мин.4 В
LT1014 LT1014
  • Designing Linear Circuits for 5V Single Supply Operation &mdash AN11
    PDF, 230 Кб, Файл опубликован: 1 сен 1985
    This note covers the considerations for designing precision linear circuits which must operate from a single 5V supply. Applications include various transducer signal conditioners, instrumentation amplifiers, controllers and isolated data converters.
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • Designs for High Performance Voltage-to-Frequency Converters &mdash AN14
    PDF, 387 Кб, Файл опубликован: 1 мар 1986
    A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.
  • Risk Assessment Advice for High Reliability Amplifiers &mdash AN141
    PDF, 299 Кб, Файл опубликован: 7 окт 2013
  • Power Gain Stages for Monolithic Amplifiers &mdash AN18
    PDF, 2.5 Мб, Файл опубликован: 1 мар 1986
    This note presents output state circuits which provide power gain for monolithic amplifiers. The circuits feature voltage gain, current gain, or both. Eleven designs are shown, and performance is summarized. A generalized method for frequency compensation appears in a separate section.
  • Application Considerations for an Instrumentation Lowpass Filter &mdash AN20
    PDF, 2.8 Мб, Файл опубликован: 1 сен 1986
    Discusses the principles of operation of the LTC1062 and helpful hints for its application. Various application circuits are explained in detail with focus on how to cascade two LTC1062s and how to obtain notches. Noise and distortion performance are fully illustrated.
  • Composite Amplifiers &mdash AN21
    PDF, 330 Кб, Файл опубликован: 1 июл 1986
    Applications often require an amplifier that has extremely high performance in several areas. For example, high speed and DC precision are often needed. If a single device cannot simultaneously achieve the desired characteristics, a composite amplifier made up of two (or more) devices can be configured to do the job. AN21 shows examples of composite approaches in designs combining speed, precision, low noise and high power.
  • A Monolithic IC for 100MHz RMS-DC Conversion &mdash AN22
    PDF, 3.3 Мб, Файл опубликован: 1 сен 1987
    AN22 details the theoretical and application aspects of the LT1088 thermal RMS/DC converter. The basic theory behind thermal RMS/DC conversion is discussed and design details of the LT1088 are presented. Circuitry for RMS/DC converters, wideband input buffers and heater protection is shown.
  • Micropower Circuits for Signal Conditioning &mdash AN23
    PDF, 2.2 Мб, Файл опубликован: 1 апр 1987
    Low power operation of electronic apparatus has become increasingly desirable. AN23 describes a variety of low power circuits for transducer signal conditioning. Also included are designs for data converters and switching regulators. Three appended sections discuss guidelines for micropower design, strobed power operation and effects of test equipment on micropower circuits.
  • Unique Applications for the LTC1062 Lowpass Filter &mdash AN24
    PDF, 587 Кб, Файл опубликован: 1 сен 1987
    Highlights the LTC1062 as a lowpass filter in a phase lock loop. Describes how the loop's bandwidth can be increased and the VCO output jitter reduced when the LTC1062 is the loop filter. Compares it with a passive RC loop filter. Also discussed is the use of LTC1062 as simple bandpass and bandstop filter.
  • Switching Regulators for Poets: A Gentle Guide for the Trepidatious &mdash AN25
    PDF, 359 Кб, Файл опубликован: 2 сен 1987
    Subtitled "A Gentle Guide for the Trepidatious," this is a tutorial on switching regulator design. The text assumes no switching regulator design experience, contains no equations, and requires no inductor construction to build the circuits described. Designs detailed include flyback, isolated telecom, off-line, and others. Appended sections cover component considerations, measurement techniques and steps involved in developing a working circuit.
  • Thermocouple Measurement &mdash AN28
    PDF, 988 Кб, Файл опубликован: 1 фев 1988
    Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.
  • Some Thoughts on DC-DC Converters &mdash AN29
    PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
    This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.
  • Applications for a Switched-Capacitor Instrumentation Building Block &mdash AN3
    PDF, 1.5 Мб, Файл опубликован: 1 июл 1985
    This application note describes a wide range of useful applications for the LTC1043 dual precision instrumentation switched capacitor building block. Some of the applications described are ultra high performance instrumentation amplifier, lock-in amplifier, wide range digitally controlled variable gain amplifier, relative humidity sensor signal conditioner, LVDT signal conditioner, charge pump F/V and V/F converters, 12-bit A/D converter and more.
  • Switching Regulator Circuit Collection &mdash AN30
    PDF, 606 Кб, Файл опубликован: 1 фев 1989
    Switching regulators are of universal interest. Linear Technology has made a major effort to address this topic. A catalog of circuits has been compiled so that a design engineer can swiftly determine which converter type is best. This catalog serves as a visual index to be browsed through for a specific or general interest.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Power Conditioning Techniques for Batteries &mdash AN8
    PDF, 708 Кб, Файл опубликован: 1 май 1985
    A variety of approaches for power conditioning batteries is given. Switching and linear regulators and converters are shown, with attention to efficiency and low power operation. 14 circuits are presented with performance data.
Design Notes
  • An LT1013 and LT1014 Op Amp SPICE Macromodel &mdash DN12
    PDF, 75 Кб, Файл опубликован: 1 июл 1988
  • Closed Loop Control with Data Acquisition Systems &mdash DN13
    PDF, 95 Кб, Файл опубликован: 1 авг 1988
  • Noise Calculations in Op Amp Circuits &mdash DN15
    PDF, 224 Кб, Файл опубликован: 1 сен 1988
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3
    PDF, 224 Кб, Файл опубликован: 1 окт 1987
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • 3V Operation of Linear Technology Op Amps &mdash DN56
    PDF, 78 Кб, Файл опубликован: 1 фев 1992
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6
    PDF, 137 Кб, Файл опубликован: 1 янв 1988
  • A Broadband Random Noise Generator &mdash DN70
    PDF, 95 Кб, Файл опубликован: 1 май 1993
Статьи
  • Low Power, DC Accurate Drivers for 18-Bit ADCs &mdash LT Journal
    PDF, 3.4 Мб, Файл опубликован: 9 июл 2013
  • Consider New Precision Amplifiers for Updated Industrial Equipment Designs &mdash LT Journal
    PDF, 154 Кб, Файл опубликован: 1 сен 2009
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Low Power Amplifiers (Is < 1mA/amp)
  • Space & Harsh Environment > Military Hermetic (M)
LT1013ACN8PBF, LT1013ACN8 PBF
На английском языке: Datasheet Linear Technology LT1013ACN8#PBF
