Datasheet Texas Instruments TMS470R1A64 — Даташит
СерияTMS470R1A64
16/32-битный RISC-флэш-микроконтроллер
TMS470R1A64 datasheet
PDF, 441 Кб, Версия: B, Файл опубликован: 1 авг 2006
MCU 16Bit/32Bit TMS470 ARM7TDMI RISC 64KB Flash 1.8V/3.3V 80Pin LQFP Tray
Триема
TMS470R1A64PNT
350 ₽
Контест
TMS470R1A64PNT
600 ₽
T-electron
TMS470R1A64PNT
625 ₽
Akcel
TMS470R1A64PNT
TMS470R1A64PNT
Статус продуктаНе рекомендуется для новых разработок
TMS470R1A64PNT
N1
Pin80
Package TypePN
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY119
МаркировкаTMS
Width (мм)12
Length (мм)12
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
TMS470R1A64PNT
  • High End Timer (HET) Getting Started Guide
    PDF, 226 Кб, Файл опубликован: 10 июн 2005
    This document serves as a guide to begin developing designs with the High End Timer (HET) advanced intelligent timer module. This timer module provides sophisticated timing functions for real-time applications. The following pages will cover a step-by-step process to program the HET. Starting with the setup for the IAR tools, descriptions of the code for the main program necessary to load the HET
  • Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUs
    PDF, 61 Кб, Файл опубликован: 17 ноя 2011
    The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
  • 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
    As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1A64 (1)
  • Semiconductors> Microcontrollers (MCU)> Other Microcontrollers> TMS470 ARM7TDMIВ®-Based Industrial MCUs
На английском языке: Datasheet Texas Instruments TMS470R1A64
