Datasheet Texas Instruments TMS320C14 — Даташит
Серия | TMS320C14 |
Цифровые сигнальные процессоры
11 предложений от 11 поставщиков Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 25.6MHz 6.25MIPS 68Pin PLCC | |||
TMS320C14FNL Texas Instruments | 273 ₽ | ||
TMS320C1-4FNL Texas Instruments | по запросу | ||
TMS320C14FNL | по запросу | ||
TMS320C14 Texas Instruments | по запросу |
TMS320C14FNL | TMS320C14FNLR | |
Статус продукта | Снят с производства | Снят с производства |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Pin | 68 | 68 |
Package Type | FN | FN |
Industry STD Term | PLCC | PLCC |
JEDEC Code | S-PQCC-J | S-PQCC-J |
Маркировка | @1991 TI | TMS320C14FNL |
Width (мм) | 24.23 | 24.23 |
Length (мм) | 24.23 | 24.23 |
Thickness (мм) | 4.06 | 4.06 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 4.57 | 4.57 |
RoHS | Не совместим | Не совместим |
Бессвинцовая технология (Pb Free) | Нет | Нет |
- A Universal Control Sys for Field-Oriented Control of AC Machines- TMS320C14PDF, 278 Кб, Файл опубликован: 1 июл 1997
The purpose of this paper is to present a universal controller system used in field oriented control method of ac machines. This controller system uses one Texas Instruments (TI(TM)) TMS320C14 digital signal processor (DSP), four analog-to-digital converters (ADC), three operation amplifiers, two current sensors and a resolver. The digital values of sine and cosine functions of the rotor position - Symmetric PWM Outputs Generation with the TMS320C14 DSPPDF, 51 Кб, Файл опубликован: 1 июн 1997
Pulse Width Modulated (PWM) signal generation is crucial to many motor and motion control applications. PWM signals are pulse trains with fixed frequency and magnitude and variable pulse width. There is one pulse of fixed magnitude in every PWM period. However, the width of the pulses changes from period to period according to a modulating signal. This document discusses how to generate symmetric - TMS320C1x Evaluation Module Analog InterfacePDF, 173 Кб, Файл опубликован: 1 янв 1993
The TMS320C16 evaluation module (EVM) is used to evaluate the performance characteristics of the TMS320C1x 16-bit fixed-point digital signal processor (DSP). This document builds a supplemental analog interface board that provides the analog capabilities commonly used by the DSP chip. This detailed document includes the schematics, the parts list, the cable connections, the power requirements, and - Minimizing Quantization Effects Using the TMS320 DSP FamilyPDF, 268 Кб, Файл опубликован: 1 июл 1994
Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
Серия: TMS320C14 (2)
- Semiconductors> Processors> Other Processors
