Datasheet Texas Instruments TLV320AIC29IRGZR — Даташит
Серия | TLV320AIC29 |
Модель | TLV320AIC29IRGZR |
Моно АЦП/стерео ЦАП с низким энергопотреблением, 6 аудиовходами и усилителем HP/динамика 48-VQFN от -40 до 85
Stereo Audio CODEC With Integrated Headphone & Speaker Amplifiers datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 2 окт 2007
Купить TLV320AIC29IRGZR на РадиоЛоцман.Цены — от 323 до 1 107 ₽ 16 предложений от 11 поставщиков Audio Codec 1ADC / 2DAC 32Bit 48Pin VQFN EP T/R | |||
TLV320AIC29IRGZR Texas Instruments | 323 ₽ | ||
TLV320AIC29IRGZR Texas Instruments | 370 ₽ | ||
TLV320AIC29IRGZR Texas Instruments | 502 ₽ | ||
TLV320AIC29IRGZR Texas Instruments | 529 ₽ |
Pin | 48 |
Package Type | RGZ |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | AIC29I |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
ADC Channels | 1 |
ADC SNR(Typ) | 90 дБ |
Analog Inputs | 3 |
Analog Outputs | 3 |
DAC Channels | 2 |
DAC SNR(Typ) | 95 дБ |
Digital Audio Interface | L,R,I2S,DSP |
Package Size: mm2:W x L | 48VQFN: 49 mm2: 7 x 7(VQFN) PKG |
Sampling Rate(Max) | 53 kHz |
- Evaluation Modules & Boards: TLV320AIC29EVM-PDK
TLV320AIC29 Evaluation Module (EVM) and USB motherboard
- How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PCPDF, 480 Кб, Файл опубликован: 14 дек 2004
Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1. - Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
- Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP PortPDF, 105 Кб, Файл опубликован: 8 июл 2009
This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications - Out-of-Band Noise Measurement Issues for Audio CodecsPDF, 145 Кб, Файл опубликован: 6 дек 2006
- Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock - Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLV320AIC29 (4)
- TLV320AIC29IRGZR TLV320AIC29IRGZRG4 TLV320AIC29IRGZT TLV320AIC29IRGZTG4
- Semiconductors > Audio > Audio Converters > Audio CODEC
