Datasheet Texas Instruments TLV320AIC25CPFBRG4 — Даташит
СерияTLV320AIC25
МодельTLV320AIC25CPFBRG4
Маломощный стереофонический голосовой диапазон CODEC 48-TQFP от 0 до 70
Low Power Highly-Integrated Programmable 16-Bit 26-KSPS Dual Channel CODEC datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 12 апр 2005
Audio Codec 2ADC / 2DAC 16Bit 48Pin TQFP T/R
TLV320AIC25CPFBRG4
596 ₽
TLV320AIC25CPFBRG4
768 ₽
HXD Co.
TLV320AIC25CPFBRG4
TLV320AIC25CPFBRG4
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
Маркировка320AIC25C
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Demo/Test CODEC System with TLV320AIC20/21/24/25 EVM
    PDF, 141 Кб, Файл опубликован: 26 авг 2002
    A demo/test system has been built as a simple example for using the TLV320AIC20/21/24/25 codecs. The hardware part of the system includes the ?AIC20/21/24/25 EVM boards, an AIC development interface board, and a TMS320C5402 DSP DSK board. The C54xx software, in assembly and C, is implemented on the ?C5402 DSP. A 2-device, 4-channel and a 6-device, 12-channel codec system are presented in this appl
  • Interface With Voice-Band Codecs Using I2C
    PDF, 231 Кб, Файл опубликован: 19 мар 2003
    This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented.
  • Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 Codecs
    PDF, 103 Кб, Файл опубликован: 30 апр 2003
    This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV320AIC25CPFBRG4
