Datasheet Texas Instruments TLC7733MJGB — Даташит
Серия | TLC7733M |
Модель | TLC7733MJGB |
Одиночный SVS для систем 3,3 В с программируемой задержкой времени 8-CDIP от -55 до 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
Купить TLC7733MJGB на РадиоЛоцман.Цены — от 36 до 8 440 ₽ 15 предложений от 14 поставщиков Микросхема: TLC7733M SINGLE SVS FOR 3.3V SYS | |||
TLC7733MJGB Texas Instruments | от 36 ₽ | ||
TLC7733MJGB Texas Instruments | 2 132 ₽ | ||
TLC7733MJGB Texas Instruments | 3 599 ₽ | ||
TLC7733MJGB Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | JG | JG |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | TLC7733M | 9750901QPA |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 9.6 | 9.6 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
# of Supplies Monitored | 1 |
Iq(Typ) | 9 uA |
Monitored Voltage 1 (typ)(Nom) | 3.3 В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Reset Threshold Accuracy | 2.4 % |
Threshold Voltage 1(Typ) | 2.93 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Watchdog Timer WDI | None sec |
RoHS | See ti.com |
- Reset Circuit for the TMS320C6000 DSP (Rev. A)PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
Серия: TLC7733M (5)
- 5962-9750901Q2A 5962-9750901QPA TLC7733MFKB TLC7733MJG TLC7733MJGB
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
