Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Texas Instruments TLC7705MJGB — Даташит
СерияTLC7705M
МодельTLC7705MJGB
SVS с одинарным питанием (5 В) с программируемой задержкой и двухтактными выходами 8-CDIP от -55 до 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
Single Power SVS (5v) W/Pgmmable Time Delay & Push-Pull Outputs 8-CDIP -55 to 125
T-electron
TLC7705MJGB
1 923 ₽
HXD Co.
TLC7705MJGB
2 528 ₽
TLC7705MJGB
2 839 ₽
LIXINC Electronics
TLC7705MJGB
Pin88
Package TypeJGJG
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаTLC7705M9751301QPA
Width (мм)6.676.67
Length (мм)9.69.6
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
# of Supplies Monitored1
Iq(Typ)9 uA
Monitored Voltage 1 (typ)(Nom)5 В
Output Driver Type / Reset OutputActive-high,Active-low,Push-pull
Package GroupCDIP
RatingMilitary
Reset Threshold Accuracy1.8 %
Threshold Voltage 1(Typ)4.55 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)6 В
VCC(Min)2 В
Watchdog Timer WDINone sec
RoHSSee ti.com
  • TLC770x Series of BiCMOS Supply Voltage Supervisors
    PDF, 327 Кб, Файл опубликован: 1 янв 1995
    This report describes the function and application of the supply voltage supervisor circuit TLC770X. Besides a detailed functional description, the behavior of line and battery operated power supplies during power-up as well as the behavior of digital circuits is presented. Finally application-examples of supply voltage supervision in general and supply voltage supervision in systems are described
  • Reset Circuit for the TMS320C6000 DSP (Rev. A)
    PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
    This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
  • Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
На английском языке: Datasheet Texas Instruments TLC7705MJGB
