Datasheet Texas Instruments TL750M10 — Даташит
СерияTL750M10
LDO с одним выходом, 750 мА, фиксированный (10,0 В), низкий ток покоя, защита от сброса нагрузки 60 В
27 предложений от 19 поставщиков
IC REG LINEAR 10V 750MA TO252-3 / Linear Voltage Regulator IC Positive Fixed 1 Output 750mA TO-252-3
TL750M10CKTE
31 ₽
TL750M10CKTE
35 ₽
TL750M10CKTPR
Allelco
TL750M10CKVURG3
TL750M10CKCTL750M10CKCE3TL750M10CKTERTL750M10CKTPRTL750M10CKTPRG3
Статус продуктаСнят с производстваСнят с производстваСнят с производстваСнят с производстваСнят с производства
Доступность образцов у производителяНетНетНетНетНет
N12345
Pin33322
Package TypeKCKCKTEKTPKTP
Industry STD TermTO-220TO-220PFMPFMPFM
JEDEC CodeR-PSFM-TR-PSFM-TR-PSFM-GR-PSFM-GR-PSFM-G
МаркировкаTL750M10CTL750M10C750M10C
Width (мм)9.029.0286.156.15
Length (мм)10.1710.179.46.046.04
Thickness (мм)4.584.581.911.911.91
Pitch (мм)2.542.542.544.574.57
Max Height (мм)4.74.72.032.032.03
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
Parameters / ModelsTL750M10CKC
TL750M10CKC
TL750M10CKCE3
TL750M10CKCE3
TL750M10CKTER
TL750M10CKTER
TL750M10CKTPR
TL750M10CKTPR
TL750M10CKTPRG3
TL750M10CKTPRG3
Accuracy(%)11111
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Thermal Shutdown
Thermal Shutdown
Thermal Shutdown
Thermal Shutdown
Approx. Price (US$)0.41 | 1ku0.41 | 1ku0.41 | 1ku0.41 | 1ku0.41 | 1ku
Fixed Output Options(V)1010101010
Iout(Max)(A)0.750.750.750.750.75
Iq(Typ)(mA)55555
Noise(uVrms)1000100010001000
Operating Temperature Range(C)0 to 1250 to 1250 to 1250 to 1250 to 125
Output Capacitor TypeNon-CeramicNon-CeramicNon-CeramicNon-CeramicNon-Ceramic
Output OptionsFixed OutputFixed OutputFixed OutputFixed OutputFixed Output
Package GroupTO-220TO-220TO-220
TO-252
TO-220
TO-252
TO-220
TO-252
Package Size: mm2:W x L (PKG)See datasheet (TO-220)See datasheet (TO-220)See datasheet (PFM)
See datasheet (PFM)
See datasheet (PFM)
Powered LoadFPGA
Microcontroller
Microprocessor
FPGA
Microcontroller
Microprocessor
FPGA
Microcontroller
Microprocessor
FPGA
Microcontroller
Microprocessor
RatingCatalogCatalogCatalogCatalogCatalog
Regulated Outputs(#)11111
Vdo(Typ)(mV)600600600600600
Vin(Max)(V)2626262626
Vin(Min)(V)1111111111
Vout(Max)(V)1010101010
Vout(Min)(V)1010101010
RoHSНе совместимНе совместимНе совместимНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНетНетНетНет
  • Semiconductors> Power Management> Linear Regulator (LDO)> Single Channel LDO
На английском языке: Datasheet Texas Instruments TL750M10
