Datasheet Texas Instruments SN75LVDS84DGGG4 — Даташит
СерияSN75LVDS84
МодельSN75LVDS84DGGG4
Передатчик FlatLink™ 48-TSSOP от 0 до 70
Flatlink Transmitters datasheet
PDF, 468 Кб, Версия: D, Файл опубликован: 6 ноя 2007
13 предложений от 9 поставщиков
IC DRIVER 4/0 48TSSOP / 4/0 Driver LVDS 48-TSSOP
Akcel
SN75LVDS84DGGG4
от 313 ₽
SN75LVDS84DGGG4
368 ₽
SN75LVDS84DGGG4
407 ₽
ТаймЧипс
SN75LVDS84DGGG4
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY40
МаркировкаSN75LVDS84
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
ProtocolsChannel-Link I
Supply Voltage(s)3.3 В
  • Time Budgeting of the Flatlink Interface Application Report
    PDF, 99 Кб, Файл опубликован: 11 июн 1997
    This document describes the FlatLinkE point-to-point data-transmission interface that provides better than a two-to-one reduction in the number of signal lines used for synchronous parallel data-bus structures.
  • Flatlink Data Transmission System Design Overview (Rev. A)
    PDF, 127 Кб, Версия: A, Файл опубликован: 1 июн 2001
    FlatLink is a data transmission system that can provide better than a 2:1 reduction in the number of signal lines used for synchronous parallel data bus structures with no loss in data throughput. To do this, FlatLink takes single-ended data at clock rates of up to 68 MHz and increases the data signaling rate seven times up to 476 Mbps. The following report provides some design guidelinesfo
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments SN75LVDS84DGGG4
