Datasheet Texas Instruments SN74LVC1G11-Q1 — Даташит
СерияSN74LVC1G11-Q1
Каталог автомобилей Одиночный логический элемент «И» с 3 входами
SN74LVC1G11-Q1, Single 3-Input Positive-AND Gate datasheet
PDF, 742 Кб, Файл опубликован: 28 мар 2011
74 предложений от 33 поставщиков
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
SN74LVC1G11DCKR
от 2.59 ₽
ЗУМ-СМД
SN74LVC1G11DBVR
2.83 ₽
727GS
SN74LVC1G11DCK
от 8.66 ₽
SN74LVC1G11DCKR
от 15 ₽
SN74LVC1G11IDCKRQ1
Статус продуктаВ производстве
SN74LVC1G11IDCKRQ1
N1
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
Маркировка7LR
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Parameters / ModelsSN74LVC1G11IDCKRQ1
SN74LVC1G11IDCKRQ1
3-State OutputNo
Bits1
F @ Nom Voltage(Max), Mhz150
Gate TypeAND
ICC @ Nom Voltage(Max), мА0.01
LogicTrue
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА32/-32
Package GroupSC70
Package Size: mm2:W x L, PKG6SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotive
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyAND Gate
Technology FamilyLVC
VCC(Max), В5.5
VCC(Min), В1.65
Voltage(Nom), В1.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс17.2,6.9,4.9,3.5
SN74LVC1G11IDCKRQ1
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G11-Q1 (1)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G11-Q1
Публикации по теме
