Datasheet Texas Instruments SN74LVC112APWRE4 — Даташит
Серия | SN74LVC112A |
Модель | SN74LVC112APWRE4 |
Двойной триггер JK с отрицательным фронтом, четким и предустановленным 16-TSSOP от -40 до 125
SN74LVC112A Dual Negative-Edge-Triggered J-K Flip-Flop With Clear And Preset datasheet
PDF, 980 Кб, Версия: M, Файл опубликован: 26 дек 2014
![]() 8 предложений от 8 поставщиков Микросхема Бистабильный мультивибратор, Flip Flop JK-Type Neg-Edge 2Element 16Pin TSSOP T/R | |||
SN74LVC112APWRE4 Texas Instruments | 17 ₽ | ||
SN74LVC112APWRE4 Texas Instruments | 21 ₽ | ||
SN74LVC112APWRE4 Texas Instruments | 22 ₽ | ||
SN74LVC112APWRE4 Texas Instruments | 23 ₽ |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LC112A |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 2 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.01 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 4.8 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC112A (16)
- Semiconductors > Logic > Flip-Flop/Latch/Register > J-K Flip-Flop
