Источники питания Keen Side
Datasheet Texas Instruments SN74GTLPH1645DGGR — Даташит
СерияSN74GTLPH1645
МодельSN74GTLPH1645DGGR
16-битный шинный приемопередатчик LVTTL-GTLP с регулируемой скоростью фронта 56-TSSOP от -40 до 85
16-Bit LVTTL-to-GTLP Adjustable-Edge-Rate Bus Transceiver datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 4 сен 2001
20 предложений от 12 поставщиков
Интегральные микросхемы Логика — преобразователи уровней сигнала
LIXINC Electronics
SN74GTLPH1645DGGR
от 19 ₽
SN74GTLPH1645DGGR
244 ₽
Зенер
Россия и страны ТС
SN74GTLPH1645DGGR
от 551 ₽
Akcel
SN74GTLPH1645DGGR
от 596 ₽
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаGTLPH1645
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)175 Mhz
ICC @ Nom Voltage(Max)40 мА
Output Drive (IOL/IOH)(Max)100 мА
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyGTLP
VCC(Max)3.45 В
VCC(Min)3.15 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)9.4 нс
  • Texas Instruments GTLP Frequently Asked Questions
    PDF, 496 Кб, Файл опубликован: 1 янв 2001
    Using a question-and-answer format, advantages of TI?s GTLP devices, particularly for backplane applications, are presented, as well as differences between GTLP and GTL/LVDS devices. Applicable topics include data throughput rates, synchronous clocks, price and alternative sources, bus transceivers, live insertion, power consumption, backplane termination, voltage translation, IBIS and HSPICE mode
  • Logic in Live-Insertion Applications With a Focus on GTLP
    PDF, 493 Кб, Файл опубликован: 14 янв 2002
    Live-insertion capability is an essential part of today?s high-speed data systems because those systems are expected to run continuously without being powered down. This application report delves into the cause and prevention of live-insertion and nanosecond-discontinuity effects, using both simulation and actual test measurements from a specially built GTLP EVM. Hypothetical cases for precharge c
  • Achieving Maximum Speed on Parallel Buses With Gunning Transceiver Logic (GTLP)
    PDF, 585 Кб, Файл опубликован: 5 апр 2001
    This application report compares two approaches for synchronous bus-system designs. The focus of the report is the comparison of a system using central-synchronous system clock (CSSC) with a system operated with a source-synchronous system clock (SSSC).The basic characteristics of lines, key factors that influence the bus line delay, and the impedance of bus lines are described.The theoretical
  • Fast GTLP Backplanes With the GTLPH1655 (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 сен 2000
    This revision of the Fast GTL Backplanes With the GTL1655 application report addresses improvements, such as the improved OECE circuitry and implementation of theTexas Instruments TI-OPCE circuitry, that have been incorporated in the GTLPH1655 device. These improvements significantly improve signal integrity in distributed loads.This application report describes the physical principles of fast
Серия: SN74GTLPH1645 (3)
  • Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74GTLPH1645DGGR
