Datasheet Texas Instruments SN74AUC240 — Даташит
Серия | SN74AUC240 |
Восьмеричный буфер/драйвер с выходами с 3 состояниями
SN74AUC240 datasheet
PDF, 608 Кб, Версия: A, Файл опубликован: 20 мар 2003
![]() 35 предложений от 18 поставщиков Микросхема Логический чип, Buffer/Line Driver 8CH Inverting 3-ST CMOS 20Pin VQFN EP T/R | |||
SN74AUC240RGYR Texas Instruments | 15 ₽ | ||
SN74AUC240RGYR Texas Instruments | от 21 ₽ | ||
SN74AUC240RGYR Texas Instruments | 113 ₽ | ||
SN74AUC240RGYRG4 Texas Instruments | по запросу |
SN74AUC240RGYR | |
Статус продукта | В производстве |
SN74AUC240RGYR | |
N | 1 |
Pin | 20 |
Package Type | RGY |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | MS240 |
Width (мм) | 3.5 |
Length (мм) | 4.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Parameters / Models | SN74AUC240RGYR![]() |
Bits | 8 |
F @ Nom Voltage(Max), Mhz | 250 |
ICC @ Nom Voltage(Max), мА | 0.02 |
Рабочий диапазон температур, C | от -40 до 85 |
Output Drive (IOL/IOH)(Max), мА | -9/9 |
Package Group | VQFN |
Package Size: mm2:W x L, PKG | 20VQFN: 16 mm2: 3.5 x 4.5(VQFN) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AUC |
VCC(Max), В | 2.7 |
VCC(Min), В | 0.8 |
Voltage(Nom), В | 0.8,1.2,1.5,1.8,2.5 |
tpd @ Nom Voltage(Max), нс | 4.8,3.3,2,1.7,1.3 |
SN74AUC240RGYR | |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC240 (1)
- Semiconductors> Logic> Buffer/Driver/Transceiver> Inverting Buffer/Driver
