Datasheet Texas Instruments 74ALVCH16501ZQLR — Даташит
Серия | SN74ALVCH16501 |
Модель | 74ALVCH16501ZQLR |
18-битный универсальный шинный трансивер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
SN74ALVCH16501 datasheet
PDF, 1.1 Мб, Версия: J, Файл опубликован: 27 авг 2004
![]() 11 предложений от 11 поставщиков Микросхема Логический контроллер, 18Bit Universal Bus Transceiver With 3-State Outputs 56-BGA MICROSTAR JUNIOR -40℃ to 85℃ | |||
74ALVCH16501ZQLR Texas Instruments | 115 ₽ | ||
74ALVCH16501ZQLR Texas Instruments | 116 ₽ | ||
74ALVCH16501ZQLR Texas Instruments | по запросу | ||
Pin | 56 |
Package Type | ZQL |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | VH501 |
Width (мм) | 4.5 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Bits | 18 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ALVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 4.9 нс |
- TI SN74ALVC16835 Component Specification Analysis for PC100PDF, 43 Кб, Файл опубликован: 3 авг 1998
The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T - Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families - Understanding Advanced Bus-Interface Products Design GuidePDF, 253 Кб, Файл опубликован: 1 май 1996
- Migration From 3.3-V To 2.5-V Power Supplies For Logic DevicesPDF, 115 Кб, Файл опубликован: 1 дек 1997
This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn - TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
The Input/Output Buffer Information Specification (IBIS) also known as ANSI/EIA-656 has become widely accepted among electronic design automation (EDA) vendors semiconductor vendors and system designers as the format for digital electrical interface data. Because IBIS models do not reveal proprietary internal processes or architectural information semiconductor vendors? support for IBIS con - Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
Серия: SN74ALVCH16501 (5)
- 74ALVCH16501DGGRG4 74ALVCH16501DLRG4 74ALVCH16501ZQLR SN74ALVCH16501DGGR SN74ALVCH16501DL
- Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
