Datasheet Texas Instruments V62/08612-01XE — Даташит
Серия | SN74AHC1G86-EP |
Модель | V62/08612-01XE |
Усовершенствованный продукт, эксклюзивный одиночный вход или шлюз 5-SC70 от -55 до 125
Single 2-Input Exclusive-OR Gate datasheet
PDF, 734 Кб, Файл опубликован: 19 фев 2008
![]() 6 предложений от 6 поставщиков Микросхема Логический чип, XOR Gate 1Element 2IN CMOS 5Pin SC-70 T/R | |||
V62/08612-01XE Texas Instruments | 18 ₽ | ||
V62/08612-01XE Texas Instruments | 31 ₽ | ||
V62/08612-01XE Texas Instruments | 33 ₽ | ||
V62/08612-01XE Texas Instruments | по запросу |
Pin | 5 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | CGB |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 75 Mhz |
Gate Type | XOR |
ICC @ Nom Voltage(Max) | 0.01 мА |
Тип входа | CMOS |
Logic | True |
Output Drive (IOL/IOH)(Max) | 50/-50 мА |
Тип выхода | CMOS |
Package Group | SC70 |
Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rating | HiRel Enhanced Product |
Schmitt Trigger | No |
Sub-Family | XOR Gate |
Technology Family | AHC |
VCC(Max) | 5.5 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 14.5,8.8 нс |
- Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74AHC1G86-EP (2)
- SN74AHC1G86MDCKREP V62/08612-01XE
- Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
V62/0861201XE, V62/08612 01XE
