Datasheet Texas Instruments SN74AHC16540 — Даташит
СерияSN74AHC16540
16-битные буферы/драйверы с выходами с 3 состояниями
16-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 379 Кб, Версия: F, Файл опубликован: 25 янв 2000
29 предложений от 21 поставщиков
Микросхема Логический чип, Buffer/Line Driver 16CH Inverting 3-ST CMOS 48Pin SSOP Tube
SN74AHC16540DL
22 ₽
T-electron
SN74AHC16540DGGR
55 ₽
SN74AHC16540DGGR
SN74AHC16540DGG
SN74AHC16540DGGRSN74AHC16540DL
N12
Pin4848
Package TypeDGGDL
Industry STD TermTSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY200025
CarrierLARGE T&RTUBE
МаркировкаAHC16540AHC16540
Width (мм)6.17.49
Length (мм)12.515.88
Thickness (мм)1.152.59
Pitch (мм).5.635
Max Height (мм)1.22.79
Parameters / ModelsSN74AHC16540DGGR
SN74AHC16540DGGR
SN74AHC16540DL
SN74AHC16540DL
Bits1616
F @ Nom Voltage(Max), Mhz110110
ICC @ Nom Voltage(Max), мА0.040.04
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА-50/50-50/50
Package GroupTSSOPSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48SSOP: 164 mm2: 10.35 x 15.88(SSOP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyAHCAHC
VCC(Max), В5.55.5
VCC(Min), В22
Voltage(Nom), В3.3,53.3,5
tpd @ Nom Voltage(Max), нс12.5,8.512.5,8.5
RoHSСовместимСовместим
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
Серия: SN74AHC16540 (2)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AHC16540
