Datasheet Texas Instruments SN74ACT3622-30PCB — Даташит
СерияSN74ACT3622
МодельSN74ACT3622-30PCB
256 x 36 x 2 двунаправленная синхронная память FIFO 120-HLQFP от 0 до 70
256 X 36 X 2 Clocked Bidirectional First-In, First-Out Memory (Rev. D)
PDF, 507 Кб, Версия: D, Файл опубликован: 1 апр 1998
15 предложений от 11 поставщиков
Интегральные микросхемы Логические микросхемы - Кольцевые буферы FIFO
Akcel
SN74ACT3622-30PCB
от 1 119 ₽
HXD Co.
SN74ACT3622-30PCB
1 434 ₽
SN74ACT3622-30PCB
1 777 ₽
ТаймЧипс
SN74ACT3622-30PCB
Pin120
Package TypePCB
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаACT3622-30
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).4
Max Height (мм)1.6
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • FIFO Mailbox-Bypass Registers: Using Bypass Registers to Initialize DMA Control (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 1 мар 1996
    The TI 32- and 36-bit FIFOs contain mailbox-bypass registers that transmit priority from one FIFO port to the other, port A to B or port B to A with out storing the data in the FIFO SRAM buffer. This document describes the FIFO mailbox-bypass registers and shows an example of direct memory access (DMA) control of a digital signal processor (DSP). The components described are the SN74ACT3641 and th
Серия: SN74ACT3622 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT362230PCB, SN74ACT3622 30PCB
На английском языке: Datasheet Texas Instruments SN74ACT3622-30PCB
