Datasheet Texas Instruments SN65LVDS32PWG4 — Даташит
Серия | SN65LVDS32 |
Модель | SN65LVDS32PWG4 |
Quad LVDS Receiver 16-TSSOP -40 to 85
SNx5LVDS32, SN65LVDS3486, SN65LVDS9637 High-Speed Differential Line Receivers datasheet
PDF, 1.9 Мб, Версия: R, Файл опубликован: 6 авг 2014
Купить SN65LVDS32PWG4 на РадиоЛоцман.Цены — от 195 до 786 ₽ 9 предложений от 9 поставщиков LVDS Receiver 100Mbps 16Pin TSSOP Tube | |||
SN65LVDS32PWG4 Texas Instruments | 195 ₽ | ||
SN65LVDS32PWG4 Texas Instruments | 697 ₽ | ||
SN65LVDS32PWG4 Texas Instruments | 786 ₽ | ||
SN65LVDS32PWG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Approx. Price (US$) | 1.35 | 1ku |
ESD HBM(kV) | 8 |
Function | Receiver |
ICC(Max)(mA) | 18 |
Input Signal | LVDS |
No. of Rx | 4 |
Operating Temperature Range(C) | -40 to 85 |
Output Signal | LVTTL |
Package Group | TSSOP |
Package Size: mm2:W x L (PKG) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
Rating | Catalog |
Signaling Rate(Mbps) | 100 |
RoHS | Не совместим |
- Evaluation Modules & Boards: SN65LVDS31-32EVM
SN65LVDS31-32EVM Evaluation Module for LVDS31 and LVDS32
- Performance of LVDS with Different Cables (Rev. B)PDF, 246 Кб, Версия: B, Файл опубликован: 11 фев 2002
This application report focuses on cable for use with LVDS devices rather than printed-circuit board interconnections. After a brief introduction to LVDS, the signal quality of seven different cables is evaluated using eye pattern measurements and TI's LVDS evaluation modules (EVMs). Since data transmission cable covers a wide range of cost and performance, this paper provides guidance for cable s - LVDS Multidrop Connections (Rev. A)PDF, 809 Кб, Версия: A, Файл опубликован: 11 фев 2002
This application report describes design considerations for low-voltage differential swing (LVDS) multidrop connections. The report describes the maximum number of receivers possible versus signaling rate, signal quality, line length, output jitter, and common-mode voltage range when multidrop testing on a single LVDS line driver transmitting to numerous daisy-chained LVDS receivers.The LVDS rec
Серия: SN65LVDS32 (9)
- Semiconductors > Interface > LVDS/M-LVDS/ECL/CML > LVDS PHY (<800Mbps)
