Datasheet Texas Instruments SN65LVDS151DAR — Даташит
СерияSN65LVDS151
МодельSN65LVDS151DAR
MuxIt™ Сериализатор-передатчик 32-TSSOP от -40 до 85
Muxit Serializer-Transmitter datasheet
PDF, 177 Кб, Версия: A, Файл опубликован: 19 дек 2000
Интегральные микросхемы Интерфейс - Сериализаторы и Десериализаторы
SN65LVDS151DAR
330 ₽
LIXINC Electronics
SN65LVDS151DAR
от 363 ₽
T-electron
SN65LVDS151DAR
502 ₽
SN65LVDS151DAR
LED-драйверы MOSO для рекламной и архитектурно-декоративной подсветки – оптимальное решение при низкой стоимости
Pin32
Package TypeDA
Industry STD TermTSSOP
Package QTY2000
Маркировка65LVDS151
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
  • Evaluation Modules & Boards: MUXIT-EVM
    MuxIt-EVM Evaluation Module
  • Performance of MuxIt(TM) with Different Cable Lengths
    PDF, 627 Кб, Файл опубликован: 20 июл 2001
    Designers are often faced with the task of moving parallel data from one location to another, over moderate distances, and in the most efficient manner. Over the last few years, a broad spectrum of low-voltage differential signaling (LVDS) serializers have become available in various clock-rate/data-width configurations. This report illustrates the performance of Texas Instruments MuxIt(TM) serial
  • The MuxIt Data Transmission System Applications, Examples, and Design Guidelines
    PDF, 920 Кб, Файл опубликован: 19 дек 2000
    MuxIt (tm) is a family of general-purpose integrated-circuit building blocks, which was designed for implementing data transmission serializer-deserializer subsystems. This application report describes the types of applications in which MuxIt can be used, introduces the individual component devices, and provides guidelines for designing MuxIt systems. System design guidelines include PC board layo
Серия: SN65LVDS151 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS151DAR
