Datasheet Texas Instruments 5962-88602013A — Даташит
Серия | SN54LS673 |
Модель | 5962-88602013A |
16-Bit Shift Registers 28-LCCC -55 to 125
16-Bit Shift Registers datasheet
PDF, 444 Кб, Файл опубликован: 1 мар 1988
Купить 5962-88602013A на РадиоЛоцман.Цены — от 7 120 до 8 560 ₽ 6 предложений от 6 поставщиков 16-BIT SHIFT REGISTERS | |||
5962-88602013A Texas Instruments | 7 120 ₽ | ||
5962-88602013A Texas Instruments | 8 560 ₽ | ||
5962-88602013A Texas Instruments | по запросу | ||
Pin | 28 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Width (мм) | 11.43 |
Length (мм) | 11.43 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 16 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 80 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 24/-2.6 мА |
Тип выхода | TTL |
Package Group | LCCC |
Package Size: mm2:W x L | 28LCCC: 131 mm2: 11.43 x 11.43(LCCC) PKG |
Rating | Military |
Technology Family | LS |
VCC(Max) | 5.25 В |
VCC(Min) | 4.75 В |
tpd @ Nom Voltage(Max) | 40 нс |
RoHS | See ti.com |
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
The Texas Instruments (TI) SN54/74LS123 dual retriggerable monostable multivibrator is a one-shot device capable of verylong output pulses and up to 100% duty cycle. The ?LS123 also features dc triggering from gated low-level active A andhigh-level active B inputs and provides a clear input that terminates the output pulse of any predetermined time independentof timing components R ext and - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: SN54LS673 (7)
- 5962-88602013A 5962-8860201JA 5962-8860201LA SN54LS673J SNJ54LS673FK SNJ54LS673J SNJ54LS673JT
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
596288602013A, 5962 88602013A
